Rear side marker lights bulb replacement
Old 03-18-2008, 11:30 AM
Pewter1
Pewter1's Avatar
Default Rear side marker lights bulb replacement
What is the best way to get to the housing to change out the rear side marker lights??? I have a bulb out, do I need to remove the tire and innner fender? or go through the trunk?
Old 03-18-2008, 12:11 PM
0TheRadioFlyer97
Former Vendor
TheRadioFlyer97's Avatar
St. Jude Donor '08
Remove your outer taillight on the side in question. Reach inside and twist out the socket. Replace the 194 bulb and replace.
Tools needed: Torx 15 or Phillips (depending on your tail light mounting screws)
Total procedure time: 2 minutes if you know where all your tools are
Old 03-18-2008, 01:44 PM
bigleman
bigleman's Avatar
thats always my problem
a 2 minute job turns into a 3 hour job.
Old 03-18-2008, 10:24 PM
Pewter1
Pewter1's Avatar
Thanks.....done deal!!
To Rear side marker lights bulb replacement
Quick Reply: Rear side marker lights bulb replacement
