Need quick answer: what kind of Ti rod for Ti exhaust bypass?
My welder isn't quite sure what grade/size rod to use to weld the Ti bypass pipes into my exhaust. If anyone could provide any insight, I'd appreciate it!
Matt
Matt
Pure titanium rod or Ti 6-4, either will work because this is a low strength fill application. Typically you would want to match the alloy you are welding together with the same or preferrably an overalloyed fill wire.
1/16th or .063, If your welder can't tell you what size filler wire he wants to use, do you think he should be welding your Ti mufflers? Welding titanium is easy compared to cutting contoured holes and creating close fitting complex shapes in titanium tubing.
He's done it before, just not on a regular basis. He wasn't sure what size rod to use as he's never done a Ti automotive exhaust...mainly aviation repairs.
http://www.timet.com/fab-p27.htm
(Timet is the supplier of the original Ti to Arvin Meritor for fabrication of the Corvette exhaust)
I would think, if he has welded titanium before, he'd know what wire size to use. Titanium is common on military aircraft, and somewhat common on commercial planes ... it is rarely seen in "General Aviation" applications ....
Is he protecting BOTH sides of the weld with Argon ???? Ti is contaminated by air when hot and becomes VERY brittle (the weld won't hold) unless both the front and back (the interior and exterior) of the weld are protected.
