Headlight Switch / Blinker Arm Removal: A How-To
#81
This just saved me hours of frustration. I owe you a beer. Got the new headlight switch from Summit for $149 shipped, took 1 hour start to finish!
#82
Just used this as well. also used your link to take apart the original turn signal. everythings back and working. i'll post an update if it quits again. note: i had a problem with the fuel door switch in the console - i took the switch apart and bent the terminals a little to make better connections, basically using that same idea/experience and your notes to do the same with the turn signal switch.
#83
I know this is an old thread, but the info is still good, EXCEPT Photobucket wants me to upgrade to the P500 plan at $300/yr, just to view the pictures.
Can anyone help, by sending me pictures or another thread? I'm at the plastic going around the steering wheel.
Thankx, gary
Thankx, gary
#87
Excellent Write UP
I did this today. I took my time and had in done in about 3 hours. Thanks very helpful.
I lucked out and I did not need to remove the torxs bolts in step 7.
