supercharger cams
Old 12-22-2001, 02:07 AM
madguy
madguy's Avatar
Default supercharger cams
What is a good cam profile for a supercharged engine and who sells them
Old 12-22-2001, 01:20 PM
madguy
madguy's Avatar
Default Re: supercharger cams (madguy)
ttt
Old 12-22-2001, 03:33 PM
Jim Shearer
Support Corvetteforum!
Jim Shearer's Avatar
I would also like to know the answer to this.
Old 12-22-2001, 04:07 PM
Redline Motorsports
Redline Motorsports's Avatar
Default Re: supercharger cams (Jim Shearer)
I would look for a cam that didn't have a small (tighter) lobe separation for starters. Something in the 114-116 range would work well. Also look for a cam that breaths very well on the exhaust side. Getting the air in will not be as hard then it will be to get it out. I'm sure as much lift as the heads will flow will also be an advantage.
Call Comp Cams!! :)
[Modified by 9D9LS1, 3:09 PM 12/22/2001]
Old 12-22-2001, 09:24 PM
intel55
intel55's Avatar
spread out to 114-116 and split duration with an extra 10-15 degrees on the exhaust side. THe blower will fill the cylinders much faster because the mix is under pressure. Now you just need to get it out faster without to much overlap, otherwise you start losing some of that charge out the exhaust.
Any cam grinder will have "blower" cams. Very much like a nitrous cam. :cheers:
Old 12-22-2001, 10:50 PM
Sully C5
Sully C5's Avatar
Cruise-In II Veteran
This is what we had for a SC... http://c5.techbottle.com/headscam.htm
Competition Cams makes the cam.
Old 12-22-2001, 11:24 PM
pkmoose
pkmoose's Avatar
Cruise-In III Veteran
Default Re: supercharger cams (Sully C5)
would having a higher compression ratio affect the choice of a cam? I see that you are running 9.0 - 9.5:1 cr
Old 12-23-2001, 12:31 AM
Sully C5
Sully C5's Avatar
Default Re: supercharger cams (pkmoose)
The cam for the SC & lower compression was 214/224 duration and .525" in and .532" ex lift on a 114LSA.
Whereas the camshaft for our new engine is a 232/232 .575"/.575" 114 cam.
To supercharger cams
Quick Reply: supercharger cams
