Differential seals? need part info..
Im having my transmission rebuilt right now.. While its out I want to take care of the differential leak I had, I want to replace the 2 side axle seals , But are there other seals needed Like the casing seals, or are those RTV?
Also What oil is recomended for the rear dif?
Banned Scam/Spammer
There's a TSB on the tranny seal. It's about $60, but you have to drop the carrier to do it. It starts leaking when the car sits in extreme cold.. then it just starts leaking..
http://corvetteactioncenter.com/kb/index.php
that tsb said its recomended that sealant be applied to the side cover on installation..
Are they refering to the side covers that house the axle seals, one cover on each side?
I need to order all my parts so im just wondering..
Banned Scam/Spammer
That's one of them. There's another though about the tranny seal. It might just be on early a4's. I'll see if I can find it.
I know about it 'cuz it happened on my 2000 coupe... right after I had replaced the rear end. So, ya, I had to drop it twice.
edit: ok, I'm calling it a tranny seal but it's the seal that goes "to" the tranny. Item 1 in the pictures
http://www.corvetteactioncenter.com/...al+Replacement
your profile is blank; no way to determine if you have an A4 or 6 speed manual.
Carrier tranny center-shaft seal (A4): 24207010 (newer substitute PN: 24228816 )
Seal Plate O-ring (A4): 12369456
aluminum 6" seal plate (A4): 12369457
89047953 (new revision) side plate outer "O" ring seal (use with anerobic sealer)
88996703 (new revision) output shaft(s) center seal
89021677 - part number for the anerobic sealer
C5 Diff Oil Leak
Be sure you have a leak before replacing the seal and "O" ring. I found after driving my 2000 hard, the Tail Of The Dragon, I had diff. lube dripping down the bottom of the side cover. It turned out to be coming from the vent located above the side cover.
An Anerobic Sealer is applied to the face only, not the "O" ring.
Is your weekend getting an early start?
