How to: Dash removal and Hud install
#62
If your two clusters have the same connectors, then a card swap should work fine.
#63
One caveat to the card swap approach. Both your old, and your new cluster must be "HUD ready". The older clusters (like on my 97) don't have the connector for the HUD, so a swap of the entire cluster was called for. In that case, you'll either need to get a dealer to change it, or swap out the eeprom on the card (which is soldered on)
Or to the soldering approach, how difficult is that? I've only soldered a couple things before in college but nothing important or expensive.
Sorry pirateslife, didn't mean to mislead you. Let me know what you find out because I'm probably going to need to do the same thing!
#64
Awesome good catch you just saved me some frustration. What exactly does the dealer need to perform the switch in mileage? I imagine I can't just go in and tell them to switch my mileage as that could be perceived as fraudulent. Do they have to do the whole install then?
check out this thread
#65
I'm not certain how the dealers do it. They may be able to reprogram the chip in place. Barring that ability, they would essentially have to program a replacement eeprom, and then solder swap it into the new cluster.
#66
Received 3,866 Likes
2015 C5 of the Year Winner
Resurrecting this thread so I can have the subscription to it. I am going to be removing my dash pad tomorrow on my '98 and this looks like a great how to. Not doing the HUD though, just some interior vent mods. Thanks for the write-up.
#67
My sincere thanks are added to the others.
I'm going in to fix a low display projection. Given the age of the car, I figure I might run into brittle clips. I would like to have them at hand before I start , since the passion to work on my car is fleeting and infrequent. Are any plastic clips involved, and what would you have on hand, just in case?
Anything else to look into while the dash is off? Are bulbs an issue?
#68
I just did mine yesterday and didn't run into any plastic parts that would break on you. Most all the mounting is with metal brackets. Mine is a '98 and I didn't have any issues with the reinstall. No bulbs that I could tell that you will find in there either. Good luck with your project.
#69
Went through this yesterday...
One minor nit-pick: last picture before step 15 (step 14 appears to be missing), leave those 10mm bolts behind the covers alone, just remove the four 7mm screws under the top edge. (It's not necessary to remove the glovebox and getting those bolts back in without three hands and a magnetic socket is almost impossible.)
#70
You might want to consider ordering replacements ahead of time if you car has spent significant time parked in the Florida/Texas/Arizona sun.
#72
In this thread is how to remove your dash and how to install a HUD: (for you mouse over people)
As I was searching the forum to find a set of instructions to remove the dash, I kept coming up with the same link:
http://home.comcast.net/~joshker99/hudinstall2.htm
Unfortunately that link no longer works. 2000-C5 however, saved a copy of it and emailed me a word document of it. I decided to upload all the pics and instructions and I'm reposting it here. If someone wants a copy of the word document, please feel free to email me. I don't know what happened to Josh's site and Josh, if you don't want me to host this info, please let me know and I'll delete it. ***I take NO CREDIT FOR THIS INFO!!! Josh did all the work on this, I'm just posting it!***I put this on my website as well, but I wanted a working copy for the forum so I put the whole thing here so if someone searches for 'dash removal' they'll find everything right here.
Also, the forum only allows 25 pics to be uploaded and there were 27 total so I removed some of the pics showing the different HUD display options as they aren't that important. Ok ok ok...enough talkin...here is the instructions
For those not familiar with heads up display, You get 9 different ways to project critical info on your windshield, like speed, Tach, gas level, oil pressure, coolant temp, turn signals, high beam indicator, shift light indicator (6 Speeds) and check gages. You can control which are displayed, adjust the height of the projection on the windshield, and the intensity. Some are shown here:
Heads up display wasn’t even offered until late 99, but for those who were not fortunate enough to get this way cool option here's the directions to install it yourself. It can even be retrofitted in a 97,98, Early 99, and 01 Z06 Corvette when it wasn't even an option. Its plug and play. Any confident installer can install it within an afternoon. The factory HUD cars have a special HUD windshield that is not necessary as the projections shown above are taken on my non-HUD glass in direct sunlight. Also all 97+ C5's have the pocket for the projector, and the outline for the dash to be cut.
The following are the necessary components needed HUD to work
• HUD projector - 10279814 - (GM LIST: $1,118.82) You will have to drill 2 small holes in the dash to mount it. Even the 97,'s and 98's have the seat for the projector
• HUD Projector Bezel - 10425223 - (GM LIST: $25.52) You will have to cut a hole in the dash and the bezel is there to cover the hole. Its very easy to do though because even the 97 and 98's have the cut marked out under the dash pad. The bezel simply covers the hole.
• HUD Enabled Cluster – This is a must for a 97-99 owner that currently doesn’t have a HUD enabled cluster. The cluster may be HUD ready or it could have come from a HUD equipped car. If it is only HUD ready you will need a HUD switch and 11 pin wiring harness.
• HUD Switch - Part # 12198648 (GM LIST: $124.04)
• The very important 11 Pin wiring harness which is not available from GM, you will have to find a harness, or you will have to build your own using your existing harness.
There are 2 different HUD install scenario's.
97, 98, or early 99 C5's without the HUD enabled cluster - You will need to get a late 99+ Cluster. The only way to tell whether you have the HUD enabled cluster is to remove the one you have and look for the white connector in the very back. If it doesn't already have the HUD Switch you will have to install one and find a 11 pin harness. If you need a HUD enabled cluster you will have to have it programmed with your existing mileage. I've heard ~$50 to do this, but contact your dealer. You will have to drill 3 holes to mount the projector, 2 in the plastic dash support, 1 in the aluminum column support. If you use a late 99-04 cluster you will also have to move the airbag warning light located next to the fuel gauge to the location on the Tach or else the light will remain lit al the time.
Late 99-04 C5's with a HUD enabled cluster - You will need the projector, dash bezel, switch and 11 Pin from the switch to cluster. You will have to drill only 2 holes in the plastic dash support, the third is already notched out.
Tools Necessary:
• A small assortment of flat headed screw drivers.
• Very sharp razor Blades
• Something to cut the plastic under the dash pad (Dremel tool, utility knife, angle grinder etc...)
• Something to drill mounting holes (I used a right angle electric screw driver with a 1/8" conical grinding bit)
• Torx T15 driver, or bit with compatible holder to use with 1/4" ratchet.
• 7mm socket and driver
• 10mm Socket with swivel and various extensions
• 1/4 ratchet for the 7mm socket
• Needle nose pliers
• 2 #10 rubber expansion nuts available from home improvement store (Lowe's, Home depot, Ace, Etc....)
• 2 Allen Screws for the expansion nuts. With proper Allen wrench.
• JB Quick Weld or similar to affix the bezel
• Clamps or similar to hold bezel
The install is pretty basic. If you have a roadster or coupe now is a great time to open the car up. This is also a great time to move both seats all the way back to allow your self plenty of room to work. I myself just completed this modification on my own 2000 Corvette on 8/5/03 and the pictures seen here are from my own install. These instructions are for a 2000 six speed coupe
Removing the Center Console:
1)Remove the center console. To do this you will need to open the console remove the little covers in the rear of the console to access the 2,10mm nuts. Remove these.
2) Move up towards the front of the console bin. Insert a flat headed screw driver or similar to pop off the panel with the Traction Control / Active Handling.
3) Disconnect all wiring.
4) Remove the 2, 10mm nuts under the cover, at this point you need to disconnect the fuel door switch and the rear center console is ready to be removed.
5) To remove the front half you will need to remove the shifter ****, and pull out the ash tray.
5a.) To remove the shifter ****, first pry the black shift pattern diagram. Then you will need a pair of needle nose pliers or similar to pull the key out of the shaft before being able to spin the **** off. I'm assuming the A4 has a clip in the front of the **** that has to be pulled straight out before pulling off the ****.
6) There are 3, Torx 15 screws holding the front of the console in. These are located
• 1. Under the temperature sensor panel, located to the right of the steering wheel. Pop off the bezel with a flat headed screw driver. Disconnect the air temperature sensor (If equipped with the dual climate)
• 2. to the Left of the cigarette lighter
• 3. behind the ash tray
7) At this point the center console pulls straight off. There are a few clips that still hold it in around the radio and climate control. Don't forget to disconnect the cigarette lighter by reaching around the back and pulling the connector off. With the center console completely removed, you are now ready to work on the panel under the steering column.
Preparing for Dash Pad Removal
8) Start by removing the Trunk release/fog light switch bezel, with a flat headed screw driver, disconnect wires. Remove the Torx 15 screw. Remove the 2, T15 screws located up top of the instrument panel directly above the steering wheel
9) Look under the dash, towards the rear and remove the 2 T15 screws. At this point you’re ready to remove the lower steering column cover. Simply pull evenly towards the steering wheel; there are 2 clips that hold near the left hand upper corner.
10) You will need to remove the radio to help reach the hazard switch to disconnect when you start to remove the dash pad. Remove the 2, 7mm screws on each side of the radio and slide it out disconnecting all connectors from the back of the radio.
11) Take a flat headed screw driver and gently pry the defroster vent grill, Disconnect the sensor on the left side and twist the sensor loose on the right, now take your 7mm 1/4 ratchet and remove the 2 screws to the outsides of the defroster
12) Remove the side pillars. To do this start from the top and pull towards the rear/center of the vehicle. Move down the pillar, there are 3 clips to completely disengage the pillars.
13) You are now ready to remove the rest of the dash pad 7mm screws. There are 2 on the top on the sides of the dash pad that were covered by the pillars. There is one on the passenger side of the dash near the hinge of the door, (look at the side of the dash with the door fully open) one near where the cluster resides on the drivers side, and the rest are visible around the stereo was
15) Once all the screws are removed from the dash pad, gently pull the dash pad away from the window. Once moved enough disconnect the hazard switch connector. This is where you’re going to probably want a helper. Finish pulling the dash out of the car.
Preparing for HUD installation
16) Its now time to drill the holes for the rubber expansion nuts or whatever you decided to use. I'm sure you could also use self tapping bolts if you can managed to get space between the window and ratchet. Place the projector in into its seat pushing it all the way towards the front of the car. Mark the 2 holes with a marker or whatever you can manage to get between the window. Also mark the column support on the pre 99 cars for the 3rd mount. The 99+ cars should already have the cutout for the screw to reside in. Remove the projector and drill. Once drilled, mount the projector with whatever method you chose.
17) Once the dash pad is out, you can flip it over and see where you’re supposed to cut. Cut to the very edge of the sides, and about a 1/4" from the bottom (Front of dash closest to steering wheel) to provide a step for the bezel to grip the dash pad. Cut slowly, KEEP cutting device perpendicular to cut while watching where the bezel rests. This is the most time consuming part of the install. Cut little by little constantly fitting bezel until snug. Cut the foam and pad with a sharp razor blade. TAKE YOUR TIME, you don't want to know what a replacement dash pad costs!!! (My diagram is for illustration purposes only)
18) Once you have the hole trimmed to fit the bezel, fit the bezel in place and hold it with some clamps. Make sure the bezel is flush with the rear edge of the dash (side under/closest to windshield) You can choose your own method to secure it to the dash pad. I mixed up a batch of JB Quick Weld filled the holes, glued the front tabs of the bezel, removed the clamps and was done. One of my customers cut the legs by enough to use screws into the legs.
19) While your waiting for your bezel to set you can use swap your stock 97-99 non-HUD cluster with the reprogrammed HUD enabled cluster, or to add the HUD switch and wiring harness to your HUD enabled cluster. To remove the cluster from the car with the dash pad already removed you need to remove 2, 7mm screws located just below the cluster and reach behind the cluster and pinch the large grey connector while pulling, rocking or whatever else it take to get it loose.
• 19a.) If your cluster came from a car with HUD already installed, install your new cluster and move to step 20
• 19b.) If you have a HUD enabled cluster that came from a car without HUD you will have to purchase a HUD switch from the dealer and swap it with your existing dimmer switch. If you can find a factory wiring harness, just plug it in, install and move to step 20
Putting your Vette back together
20) Congratulations take a step back and look at the mess you've created. Maybe have a drink or two, because reinstalling it all is the easiest and fastest part.
21) Plug in the main cluster harness, and now the HUD projector harness to the back of the cluster. Key the ignition on and make sure everything works. All the gauges should do they're full sweep as well as the projection on the windshield should do similar.
• Play with the intensity, make sure it gets bright, dims, disappears...
• Cycle through the page button, to switch displayed fuel level, coolant temperature, oil pressure, also hold it briefly to switch Tach on/off cycling through the different views.
• Also move the display up and down the window to make sure everything is hooked up correctly.
• If everything appears to work correctly move on to step 22. (make sure you firmly plugged in the fuel buttons on the right if you installed the HUD switch)
22) Re-install the 2, 7mm screws holding the lower cluster in.
23) Don't forget the sensor, and wire harness you disconnected from the defroster grill. Tape them up to the defroster so they will be accessible when you reinstall the pad
24) Get your helper grab the now "HUD enabled" dash pad and move it back into place. Before pushing it all the way back toward the window, make sure to hook up the hazard switch. (Forget to do this and your turn signals will not work)
25) Re-install the various 7mm screws you removed throughout, not forgetting:
• 2 under the defroster vent,
• 2 off to the side/under the pillars,
• the one on the side near the passenger hinge area.
26) Re-install the 2, T15 screws above the cluster to dash pad
27) Re-install the side pillars by starting in the bottom, and working to the top
28) Re-install the stereo with 2, 7mm screws
29) Re-install the glove box, get all the 7mm screws, and 2, 10mm bolts in loosely before tightening everything down
30) Re-install the center console not forgetting to hook up all electrical connections
31) Re-install the shift ****/selector
32) Sit back and take a look at a job well done, hopefully there will be no mysterious screws left over.
Tools Necessary:
#73
HUD Install Complete - 2000 Vert
Installed my HUD yesterday. Thanks for this DIY. I never would have attempted it without this set of instructions. Even with this DIY I was afraid to tackle the install but i got the courage and guess what? It was easier than I thought it would be.
On a different note, it seems every single thing made of plastic in this car is SUPER fragile... LOVE THE HUD!!! THANKS!
#74
Some day!!! More than anything, I just want to pull it out and clean and insulate under there. Find any sources of rattles and squeaks. The HUD would just be a bonus.
Only thing I don't like is the giant hole in the dash. They look so much nicer without the projector. Small price to pay for that feature though.
#76
Supporting Vendor
I'm currently in the process of doing this. Thankfully my 02 was already HUD enabled so I just needed the projector and controls which i grabbed of ebay for $250
I wish i could say my install was simple, but I have WAY more wires and toys in my dash than the average vette....but this gives me an opportunity to organize wires and clean things up.
Note: Cutting the dash for the bezel can be done VERY quickly and effectively with a dremel multipurpose cutting bit.
#77
I have an 04 C5 Z06, I like the write up except I can't see the pictures. My HUD has fallen in. I hope to do this soon but still thinking if I can do it like the C6 by cutting the AC/Heater vent behind the gauge cluster thus not having to remove the entire dash......
#78
For what it's worth, I installed the HUD into my 2000 C5 and removing the dash was easier than the instructions might imply... Hope you get it figured out, I know that situation would drive me crazy
#80
i have to agree also, take your time and use common sense a few of the fasteners are hidden like the ones under the defroster vent on top of the dash keep that in mind IIRC there is also one on each side under the pillar trim peaces I hade mind out in less then an hour
these cars are really not hard to work on
