How to: Dash removal and Hud install
#84
Sorry everyone!! I didn't know that the pic links were broken I've now updated them to a new location. Apparently Comcast changed their URL's or deleted my pics and I didn't realize it. I've now moved all the pics over to my PhotoBucket account so hopefully they'll be there from now on when someone needs this guide.
#85
Thanks for this excellent diy write up. Definitely on my list to do as soon as I gather everything up. Thanks again for making this a possibility.
#86
Sorry to bump this old thread. Two quick questions...
1) I have a 2001 Z06 - my cluster should be HUD enabled already, right? So all that I need is the 11 pin harness and the HUD switch?
2) Do I need to buy a projector that's specifically from a Z06, or are all C5 projectors the same?
#87
1) I have a 2001 Z06 - my cluster should be HUD enabled already, right? So all that I need is the 11 pin harness and the HUD switch? Correct
2) Do I need to buy a projector that's specifically from a Z06, or are all C5 projectors the same? All projectors are the same.
You might want to contact Marc at VetteNuts, he should be able to fix you up with everything you need.
https://www.corvetteforum.com/forums...enuts-net.html
Good luck... GUSTO
drwprtcht (01-18-2017)
#88
By all means purchase a new dash board bezel, do not try to reuse an old one. The sun does a number on them and while they will last a very long time if undisturbed, if you try to remove and reinstall one you will soon be replacing it. It will end up cracking when installed or shortly thereafter.
Good luck... GUSTO
Good luck... GUSTO
#90
I am new to the C5 world and looking to purchase one. If I get a pre late 99 I will be doing this HUD set up. What I'm trying to figure out still is about the note about the airbag light. It says pre late 99 to get a late 99+ cluster, but you then have to move the airbag light by the fuel gauge to near the tach. That part is what I'm not getting. It looks like they all have that light by the fuel gauge. Can someone clarify this for me please.
PS: this is the exact note on page one.
If you use a late 99-04 cluster you will also have to move the airbag warning light located next to the fuel gauge to the location on the Tach or else the light will remain lit al the time.
#91
I did not have that issue with my 2000 Convertible
The hardest part for me was pulling the dash but I had the interior pulled out for dynamat so I did the upgrade. I bought the used HUD from VetteNuts (if I remember correctly) and it was plug and play. My only warning to you would be to take your time cutting the hole in your dash for the HUD it is marked from the factory but you want to keep it tight. The last thing you want is for your cut to be peaking past the bezel. Good luck. I really enjoy having HUD
#94
My question only has to do with the airbag warning light on the dash. From page one I know I need the projector, correct cluster, the harness, HUD switch and HUD bezel.
#95
Running Guns & Moonshine
FAKE NEWS!
You don't need to change out your cluster or worry about having GM re-flash your mileage or swap the chipset over (can be done - instructions are on the forum.)
If you search my name on here and "hud" you will find my experience.
I have an early 99, built in 98. I opened it up to find that I did NOT have the so-called Hud-enabled cluster. No connector. I figured if I was going to get rid of my cluster anyway for one that worked... what the hell... so I tried soldering in the connector to the board where it was clearly designed to support the system. It worked, and has been working since... 2015? 2014? I don't recall. I had no issues with lights in the dash.
NOTE: I have not verified application to 97/98 cars. Some people have attempted it and PM'd for advice, but I never heard back from them on here.
#98
I have a hud kit for sale currently. If you decide you're ready to do it hmu.
#99
I do not recall the vendor. I'm trying to think because I KNOW I saw those little connector tabs somewhere. I bought them in a pack of ten or so. If I can find them this weekend, I'll respond back and send what you need. Don't hold your breath though... I have been at full on project speed trying the rip the car apart and put back together over the past two weeks in time for a veteran support car show this coming weekend. Those little buggers could be ANYWHERE in the house.
I do remember finding the info/vendor through long reading of HUD install posts on the forum here. Somewhere, the information still exists in written form.
Edit: Possibly Newark.com? Unsure.
#100
Stroker thanks for the information on the airbag.
Oneandgone I will let you know when I am ready and hopefully you still have it by then. I still need to find a Vette first, but going to look at a couple this weekend or next. So if all works out I should have my C5 very soon.
Tusc thanks for the information I will look on their website and see what I can find. Good luck getting your Vette ready for the Veteran support car show!
