C5 Skip Shift Eliminator?
Old 07-16-2008, 10:36 AM
JIMVET
JIMVET's Avatar
Default C5 Skip Shift Eliminator?
Anyone who has a C-5 6 speed knows about the 1-4 shift.
Has anyone installed a Corvette C5 Skip Shift Eliminator?
Are they safe and do they work?
Jim
Old 07-16-2008, 10:54 AM
THE TECH
THE TECH's Avatar
May want to do a search on that one.
Old 07-16-2008, 11:12 AM
8VETTE7
8VETTE7's Avatar
Received 1,818 Likes on 1,613 Posts
I have one on my 04 Vert. Not exactly sure how they work but the end result is that when the skip shift light comes on you are no longer locked out of 2nd and 3rd. Only had mine on for several months but I can't see how they would not be safe. I have heard that GM installed the Computer Assisted Gear Shifting (CAGS) to avoid the gas guzzler tax. May be an old woves tale for all I know. All I can say for sure is that it is a pleasure to not have to shift 1 to 4 when the CAGS decides to kicks in.
Here's a link to an older thread about CAGS:
http://forums.corvetteforum.com/show...highlight=cags
Old 07-16-2008, 11:16 AM
Classical Glass
Classical Glass's Avatar
I've had mine for about 5 years on my 02 Vette and no problems. At all, none. The only reason the General put this on the car was to make the gas milage a tad better, nothing more.
Old 07-16-2008, 11:17 AM
KenHorse
KenHorse's Avatar
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,401 Likes on 1,366 Posts
St. Jude Donor '11-'12-'13, '16-'17-'18
Best $20 I ever spent on my Z06!
Seriously, it's very easy to install (took less than 2 minutes once the car was on the lift).
An alternative - if you know someone locally who can reprogram your computer - is to have the CAGS programmed out.
Old 07-16-2008, 11:23 AM
RBChallenger
RBChallenger's Avatar
Mine also has had one for right around 6 years in it.. works great. 1-4 skip shift == annoying, you wont regret it.
Old 07-16-2008, 11:27 AM
C5 ChemE
C5 ChemE's Avatar
I've had mine on the car 4 years now and no problems, just miles of smiles! Do it- you won't regret it.
Old 07-16-2008, 05:06 PM
FKING1
FKING1's Avatar
Easiest install you will ever do.
Old 07-16-2008, 05:29 PM
Navybluevette
Navybluevette's Avatar
St. Jude Donor '12-'13-'14-'15-'16-'17
Had mine since when the car was new in 2001. The dealer even installed it for me. The only problem is the 1-4 shift lite still comes on.
Old 07-20-2008, 04:25 PM
m-nelson
m-nelson's Avatar
Has anyone installed a Corvette C5 sloenoid?
Jim
They are safe & real simple. Consider this, you could disable the Skip-Shift by just unplugging it. The problem is the vehicle computer detects the disconnect as a broken wire or burned out solenoid & makes an error code. You avoid that by plugging in an approprate resistor (the Skip-Shift Eliminator).
Now the computer is happy (it detects what it thinks is the solenoid) & you're happy becuase it's just talking to a dummy device.
Old 07-20-2008, 04:48 PM
gdaddee
gdaddee's Avatar
You can substitute a 220 ohm 1/2 watt resistor for the $20 device. That's what I did.
Old 07-20-2008, 05:01 PM
skipsville
skipsville's Avatar
Location: Mtns of north Georgia - Hey Kids, I'm spending your inheritance!
Why spend $20. Why that's half a tank of gas. No, wait.....1/4 tank...., no it's 5 gallons, no....4, ?????...less???? LOL
You don't need it. You have several options:
1. Simply exceed 17 mph in 1st gear. Oh, bumper-to-bumper traffic you say???
2. Double clutch between 1st and 2nd. (This blows the computer's mind.)
3. Shift from 1st to 3rd (bumper-to-bumper traffic remember) The engine is a torque monster, it still pulls stong and you won't bog down.
4. Best advice - see first half of #1.
Old 07-20-2008, 05:19 PM
mitchcole
mitchcole's Avatar
2200 ohm resister. one more zero. Radio shack = 5 for $0.99. Line them up!
I shoved one in the connector about two years ago - no problem!
Old 07-20-2008, 09:03 PM
RBChallenger
All this would have worked OK for me but I sorta like to baby the car around when I am not thrashing around in it. Personally, I suggest either using the resistor or getting the $20 kit... but to each their own.
Originally Posted by skipsville
Why spend $25. Why that's half a tank of gas. No, wait.....1/4 tank...., no it's 5 gallons, no....4, ?????...less????
2. Double clutch between 1st and 2nd. This blows the computer's mind.
3. Shift from 1st to 3rd (bumper-to-bumper remember) The engine is a torque monster and it still pulls stong.
Old 07-21-2008, 07:03 AM
gdaddee
gdaddee's Avatar
You see what happens to the mind as you are mired in the "golden years" of life!
Thanks for the correction.
Old 07-21-2008, 08:15 AM
Tom/99
Tom/99's Avatar
I installed one in my 04 coupe the day after I bought it. That's over 4 years ago. There is no way I would be without it.
Old 07-21-2008, 12:11 PM
Oldvetter
Oldvetter's Avatar
Install one, one of my best mods.
The shift wiring actuates a solenoid which blocks any shift from first to any gear but fourth. The computer looks for proper rssistance of the solenoid, to make sure it is connected and working properly, if not it sets a code.
The bypass shows the proper resistance, the light comes on, but no solenoid or code, GREAT.
I recommend buying the commercial product, it has the proper weather sealed connector to prevent corrosion.
To C5 Skip Shift Eliminator?
Old 07-21-2008, 03:01 PM
napacruzerc5
napacruzerc5's Avatar
Haven't found a need for the eliminator. 17 mph in 1st isn't abusing the engine/tranny and just can get it into 2nd easy. Just DRIVE it!
Old 07-21-2008, 04:53 PM
Brianj
Brianj's Avatar
Old 07-21-2008, 05:13 PM
dougbfresh
dougbfresh's Avatar
I did this for a while-annoying in heavy traffic. All it is is a 22 ohm resistor-I measured the one in the COH version when it died (bad solder connection).
Quick Reply: C5 Skip Shift Eliminator?
