Abs Warning Light( 2002 Vette )
Can Someone Help, I Have A 2002 Vette. Today My Dic Messages Came On Reading: Service Abs, Service Traction System, And Service Active Handling Along With The Abs And Traction Control System Warning Lights. Less Than 50 Miles Ago I Had New Tires And A Allignment Done. (at A Non Chevy Dealer ). Could They Have Done Something Wrong To Activate These Warnings Or Is There A Way Of Repairing This Without Going To A Chevy Dealer ??
You need to display your DTC data. If you don't know how to do it go here ....
https://www.corvetteforum.com/techti...D=26&TopicID=1
When the AUTOMATIC display completes it will enter MANUAL mode. In that mode display and write down what codes you have.
A code looks like this ...... P 1234 C
The first letter will be either a P, B, C, or U ..... indicating which system the code is for.
The following 4 numbers are the code
The last letter will be a C or an H (sometimes both).
Post the ENTIRE code (as in the example ..... P1234C), and list ALL the codes found.
The DTC will tell what is wrong.
sounds like...
...the EBCM's C1214 code is rearing up its ugly head again? If so fellows... PM me your email address, and I will send you my 12 page Word Document tutorial with photos on "how to diagnose & the cure"...
You'd have to be nuts not to send him your email addresses .... I can GUARANTEE you will find no better source of information than trussme on problems with the ABS/Traction Control/etc. systems.
Grab that document and start reading ......
Interesting. These messages just came up for me as well, twice so far. they reset after turning the car off.
trussme, PM on its way!
