Rear Lower Ball Joint Boot Replacement - How To???
Anybody have a write up on the easiest way to get the rear lower ball joint boot off to replace the boot? Mine is ripped. I'm not sure what has to be removed to get at it or the sequence.
Help would be much appreciated.
Rick
Rick
I've used this guide, you obviously won't hve to do all of it. I'd also look at jegs for a replacement boot.
http://www.jakelatham.com/C5/misc/C5...el_Bearing.doc
