What is the operating temp for a Automatic transmission for the C5?
There is a temp sensor in the tranny that monitors temp and sends a warning if it exceeds a certain level:
"High Trans Temp"
This message is displayed when the PCM detects a transmission fluid temperature (TFT) equal to or greater than 130°C (266°F) for 5 seconds.
The tranny can work in any normal environment where this temp is not exceeded, although, keeping the temp considerably lower will dramatically extend its life. I added an aftermarket tranny cooler when I swapped in 3.42 gears and a high-stall torque converter.
Here are the temp sensor specs
"High Trans Temp"
1974 LS4 (12-29-2022)
4th Gear
Sorry to dredge up such an old thread, but I have been scouring web searches and every manual I could get my hands on for days to get a chart like this.
I am converting my T56 Caprice to a 2002 Z06 PCM. The wiring harness has the wires and the PCM pinout shows the sensor, but buying a new one and the associated connector is going to chew through some serious $$$ and I am wondering if I can substitute something more common sensor and connector. Having the temp/resistance table is the key. The title of the image says A4. Do you know if this is the same spec for the M6 sensor?
Thanks, Scott
Thanks, Scott
2001, auto, automatic, c5, corvette, normal, oil, operating, temp, temperature, temperatures, temperaturre, trans, transmission, vette
