PCM removal
Old 01-02-2009, 06:16 PM
etsfl
etsfl's Avatar
Default PCM removal
Due to a leaking battery I need to remove the PCM on my 98 ,so I can clean the frame and PCM.
Did a search and removal looks easy.
However I have one concern.
When I reinstall the same PCM is there any special procedure that needs to be follwed when I restart the car?
Old 01-03-2009, 08:11 AM
clif
Support Corvetteforum!
clif's Avatar
St. Jude Donor '09-'10
Irecently pulled my PCM to send it off for a mail-order tune. It was a pain getting it out of its mounting bracket. In fact, I broke my bracket trying to get it out!
No worry, though. I was able to buy a replacement from the local dealer if under $20.
It is just that my car is a 99, and the PCM had never been removed. Yours being a 98 with battery acid on it may be stuck too! Be careful, and have a backup plan!
As for anything else, no, nothing special has to be done. just make sure you disconnect the battery before you start!
Old 01-03-2009, 02:23 PM
waddisme
waddisme's Avatar
Just a quick note - make sure you seat it all the way back in when you reinstall. Car won't run if not.
To PCM removal
Quick Reply: PCM removal
