Is underhood light on a fuse?
I tried changing my underhood light to a LED. I pulled the original one out and attempted to put new one in. While installing it flashed a few times when connections rubbed and quit. I put in original one back in and it doesn't work either. Did I blow a fuse? Looked in owners manual but found nothing. help please. Tom
Received 8,928 Likes
Here is the Monitored Load Relay schematic.
Underhood Lamp
Battery positive voltage is applied at all times to the MONITORED LD relay 37 coil and switch side. The BCM applies a ground to the MONITORED LD relay 37 coil side, energizes the relay and closes the switch contacts. The BCM then allows battery positive voltage to the MONITORED LD fuse 2 and the underhood lamp. When the underhood is opened, its switch closes providing a ground circuit, and the underhood lamp illuminates.
Bill
Underhood Lamp
Bill
I'm a toolmaker and I read blueprints but this electrical stuff is very confusing. Are you saying that the #2 minifuse under the dash is blown. 10 amp I believe?
That fuse could be blown but you would also be missing your I/P lights and vanity mirror lights. If those are still working the fuse isn't blown.
Bill
Bill
Received 1,497 Likes
No-IL Events Coordinator
C6 of Year Winner (appearance mods) 2019
2018 C6 of Year Finalist
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
I did the same thing. The LED doesn't go completely out after the retained power shuts off so it glowed all the time the hood was open. I went back to stock bulb and blew the #2 fuse as mentioned above. It's in the passenger footwell BTW.
