C5 Hyperflash with LED's
great info thanx
Sorry to bring up an old thread but does anyone know where to source the GM plugs for this harness to eliminate cutting? I know a few forum vendors get them and make their own harnesses. I can't see paying $70 for a flasher and 2 plugs honestly. I have the flasher but I need to obtain the plugs. I've gotten a ton of weatherpack plugs and even some GM pigtails from I think it was Del City but I cannot recall as it's been years since I've needed them. Anyone have any input? Anyone have a GM part # or casting # of that flasher plug?
Dave
Dave
Dave
Dave
http://www.posi-products.com/posiplug.html
You don't have to cut any wires!! You just need to tap into them with some sort of wire taps like these that I prefer or the ones from Autozone and Advanced.
Dave
I have every bit of my Nitrous Outlet kit hooked up with the Posi Tap type of taps. I use them in both of my cars Subaru WRX and my Z06. I have both of my cars hooked up that way with the Posi Taps using the relay harness I purchased for both cars. They are much better than the Autozone or Advanced auto type of taps that you can buy. I'm extremely particular on how I hook up my electronics and such. If you can find an OEM type plug then hats off to you.
That's not a very good idea. You are putting the new flasher in parallel with the factory flasher. You want to disconnect the factory flasher.
Dave
No. The 4-way uses a different (constant) power feed and there are different output feeds to the corner lights. Pushing the switch changes a bunch of switch contacts and re-configures how it's connected.
Why isn't it a very good idea please explain?? My emergency flashers work perfect as with the very same set up with my Subaru WRX as my Z06 and has worked flawlessly for quite sometime now... and I haven't seen anyone else complain or having problems with doing it this way. Thanks
Thanks, tapping into wires w/o soldering/shrink tubing just isn't how my cars are wired. I'm very particular and **** about wiring and I want everything to look factory. I spent hours wiring up a remote starter in my DD just because I wanted it to look as if it was put there by the manufacturer. if you bypass the OEM flasher by cutting those two wires, do you lose your 4 ways?
Dave
Dave
I have two totally different makes of cars Z06 & WRX domestic and import 10 and 12 sec 1/4 mile cars and it works PERFECTLY fine on both of them. Hell.... I even had my 06 Yamaha YZF-R1 done the same damn way and it's a motorcycle and I never had any issues with it done this way... along with many many other of my sport bike buddies.
For what it's worth I have personally changed every bulb over to LED's on my Z06. Instrument panel cluster, doors, under hood, turn signals, taillights, stereo, hvac, tag, glove box, map lights, floor etc. even changed over to Hid's and a 4 on harness. I have also installed many many nitrous systems, rpm window switches, fuel pressure safety switches, nitrous bottle heater pressure switches, EGT gauges, wide band gauges the list goes on and on so I think I know what I'm doing.
#33
It's utter stupidity to leave a malfunctioning electrical component connected and just slap another component over top of it. I won't recommend anyone do that no matter what you post about it.
This makes absolutely no sense. You can buy simple direct replacement LED flashers for both of these. So, why would you hack a flasher into the harness?
#34
Thanks for the UTTERLY stupid CLEAR DETAILED explanation that you gave for everyone else that's trying to save a buck that I asked you to provide for other people. I don't need it because I already know what you are trying to say. I just wanted to hear it from the horses ***... I mean mouth!! Ha! Ha!
I will be sure to hit you and this thread up every 6 months to a year to let you know that everything I have hooked up is still in great working order.
#35
Why don't you take your name calling and **** off. Since you think you're so smart and know so much more than everyone else go start your own thread about it and leave mine alone.
#36
Back on topic, I installed the 2 prong flasher and the turn signal hyper flash is gone, HOWEVER the 4 way hyper flash still persists unless I turn the turn signal on. Anyone have any input on that?
Thanks much.
Dave
Thanks much.
Dave
#37
There is no easy fix for that one. The flasher and switching for the hazards is all integrated into the switch so you can't just replace the flasher for hazard use like you can for signal use. You could fix it, but you'd have to figure out how to separate the hazard switching and the flasher inside the switch.
#38
OK so at least that is standard operating method right? I can live with it if its normal and there is no easy way around it. I rarely, if ever, use my hazards anyway. I could always just turn the turn signal on if it annoys me while they are on.
Dave
Dave
#40
