Zip corvettes lowering kit
any feedback from these guys? its the cheapest kit available looks to be pretty good comming with the c6 bolts for the front. anyone have any experience with this kit will it give me that slammed look?
tried searching but had no luck
here is the link
http://www.zip-corvette.com/Zip/prod...8829E4736B3AF5
here is the link
Many threads on this, should find with a search. Don't waste your $$ on a kit.
Cut the front bushings and buy longer Grade 8 bolts for the rear at a fastener shop.
I've read that cutting the stock bushings results in a very harsh ride.
I wonder how those bump-steer kits work, but regarding ZIP, I've bought many things from them when I had my 68 and they have always been a great company to work with.
Platinum Supporting Vendor
__________________
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles
1 Post
I have the bump steer kit but have not installed it because it requires a very special 4 wheel alignment rack with "movable tables" and loads must be put on different locations with a come along during the alignment.I dont know of any shops with that kind of equipment in Knoxville.Anybody else put one on and how did it go?
We manufacture our own lowering kits and the pads are made to our specifications by a very well known polyurethane bushing company. The bushings are the same poly that is used in the control arm bushings. I used to cut the original's also but we found a better way to do it, cutting all of the bushings off will result in control arm damage. The lowering bolt is made of steel and the lower control arm is aluminum so you can see where these will not wear very well together.
Justin
Justin
well i ordered the kit a few days ago i cant wait to slam the vette the stock bolts just dont get her down enough. great price for them too one of the cheapest kits available
