cabin air filter
This is about as close as your going to get to a C5 cabin filter
http://www.ecklers.com/product.asp?p...6&dept_id=1591
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can remove the COWL Cover and you will see where the air enters the HVAC System. You can fab up a small filter that will easily filter the air.
BC
BC
On my Toyota 4Runner, it was time to change and I read (on their forum) about replacing the filter with one made from a home HVAC filter. For the price of one filter $8, I made six to go in the Runner.
You should be able to get in the "intake" area of our system and make a filter to at least catch the big stuff.
Good Luck
I could see how you could easily fabricate cabin air filters out of furnance filters. They are the same material as the "v shaped" premium home furnace filters. Just cut the filters to size and use the "old outside frame or some kind of tape" for frame. Those cabin filters ARE expensive, $15-30.
I have not seen what the "air intake" under the C5 cowl looks like, but I think it could be much harder to fabricate one for it.
1 Post
