LS2/3 oil pan on my 01 Z06 LS6
I know the C6 oil pan will fit my can and that the LS2 and 3 are the same pan except for one bolt hole that doesn't metter.
My Z needs a oil pan gasket so I am going to swap to the C6 oil pan while I am at it.
I just want to know what parts I need to get it done.
Do I need the new pick up and windage tray part #s 12588189 and 12558750.... for my LS6 or do I just need the pan and gasket?
no body? I am guessing that all I need is the pan and gasket... If the pick up is the same then the windage tray should be too....
