Tunnel Plate Dimensions
Old 04-30-2009, 04:23 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Default Tunnel Plate Dimensions
Does anyone know the Length and width (at the widest point) of the C5 tunnel plate? Thanks in advance!
Old 04-30-2009, 05:56 PM
Last C5
Last C5's Avatar
The stock tunnel plate is 43" long and 12 3/16" wide at the widest.
Old 04-30-2009, 11:14 PM
MTPZ06
MTPZ06's Avatar
Just what I needed to know! Thanks!
Old 05-01-2009, 11:56 AM
HP_Addict
HP_Addict's Avatar
Making you own plate. PM me your email and I can send you a CAD drawing that I used for mine.
Old 05-01-2009, 12:38 PM
Eric D
Eric D's Avatar
St. Jude Donor '09-'10-'11
What are the advantages of making a new cover plate compared to the stock unit?
Old 05-02-2009, 12:43 AM
Last C5
Last C5's Avatar
My wife wraps my lunch in tin foil that's heavier than the metal they use for the stock tunnel plate. The after market plates stiffen the car, reduce heat (dramatically if they're ceramic coated), and quiet the car a little. They make a noticable difference.
Old 05-02-2009, 01:00 AM
MTPZ06
MTPZ06's Avatar
Yup, and needed to know what size of material I needed to get a hold of to fabricate. Also looking to do my own "thermal abs" upgrade. Summit/Jegs sells a sheet of "Thermo-Tec" adhesive backed heat shield in 24"x48" size for about $60.
Old 05-02-2009, 08:44 PM
Corvette Don
Corvette Don's Avatar
I did the budget 1/4 tunnel plate by riviting 2 C6 plates together and using them. Works great
To Tunnel Plate Dimensions
Quick Reply: Tunnel Plate Dimensions
