2002 LS6 cam specs
Old 02-04-2002, 11:46 AM
exracer28
exracer28's Avatar
Default 2002 LS6 cam specs
Anyone have the lift and duration numbers for the 2002 cam?
Old 02-04-2002, 02:35 PM
MySea6
MySea6's Avatar
Default Re: 2002 LS6 cam specs (T1Z06)
2002 LS6 Cam: 204/218 .551/547 Int CL:120
Exh CL:115 LSA:117.5 Cam Base Circle 19mm
Old 02-04-2002, 03:22 PM
rwj383
rwj383's Avatar
Default Re: 2002 LS6 cam specs (MySea5)
wow...there's that much difference in duration between I and E?
Old 02-04-2002, 03:32 PM
J-Rod
J-Rod's Avatar
Ok, here is your answer plus a bunch of info you could probably care less about.
The stock LS1 cam is .500/.500 198/208.
The 2001 Z cam is 0.525/0.525 204/211.
For 2002 Z cam is 0.551/0.547 (I didn't have on hand, see other post in this thread)
And for useless trivia here are the MTI cam specs to compare it to...
Cam Lift Duration LobeSeparation
Intake Exhaust Intake Exhaust
A1 .532 .558 209 216 114
B1 .558 .558 221 221 114
C1 .566 .566 .222 .222 112
T1 .558 .558 221 221 112
R1* .560 .560 232 237 114
For 2002 camshafts you get .324 intake lift at the cam
Here is what bigger rockers with the 2002 cam get you for gross lift
1.8 .583
1.85 .599
1.9 .615
2.0 .648
2.1 .680
.321 exhaust lift at the cam
1.8 .579
1.85 .595
1.9 .611
2.0 .643
2.1 .675
As stated the 2002 camshaft has 116 degree lobe separation
Jesel PN#'s for LS1/LS6
1.7 K2A-3012203
1.9 K2A-3022203
2.0 K2A-3032203
Old 02-05-2002, 12:34 AM
bparker
bparker's Avatar
Default Re: 2002 LS6 cam specs (J-Rod)
Groovy
Old 02-05-2002, 01:30 PM
exracer28
exracer28's Avatar
Default Re: 2002 LS6 cam specs (bparker)
Thanks.....
Now it's off to shop :reddevil
To 2002 LS6 cam specs
Quick Reply: 2002 LS6 cam specs
