Heads upgrade advice - 205cc or 225cc?
I need help selecting replacement heads. I'm an amature at best for choosing heads so any basic knowledge you can impart would be helpful. Currently I have LS1 ported heads with 2.02/1.57 valves. I've had them for about 5 years and there are so many better options now. I will also be upgrading to a FAST 92mm w/tb.
Which of these heads will best compliment the rest of my mods?
Choices I'm considering:
205 or 225cc afr or trickflow
patriot performance LS6/LS2 2.08"/1.60" 64cc
Are afr 225cc or trickflow 225cc to big for my other mods? I've noticed that most people with similar mods as me go with 205cc heads. AFR's website also says you "might" lose low end torque with the 225cc.
Are AFR and Trickflow worth the extra money?
current mods:
ported ls1 heads w/ 2.02/1.57 valves
XE-R 224/228, .581/.588 LSA 114
LS6 Intake (upgrading to FAST 92 with new heads)
Lucas 36lb injectors
Haltech intake (I have a vararam in the mail)
Longtubes, high flow cats, x-pipe, b&b triflow
LUK Aluminum Flywheel (will be installing a monster w/still billet fw soon)
Underdrive pulley
current mods:
Underdrive pulley
I just swapped from Dart to AFR heads with a small cam. If done right, it can be a nice street package and still get good mileage to boot. If you are interested in AFR, send a PM to Tony Mamo (he is in the member list). Tony designed the AFR 205 and 225 so who better to offer guidance and help.
I vote for the AFR 205 heads. The Trick Flow heads are 215, and with the cam you've got, 215 is iffy and 225 is too big. There is no "might" about losing some low end torque with the larger heads. Unless you want your performance up high, stay with the smaller ports and higher velocity. Of course, there will now come the obligatory "a good tuner can make bigger heads work like smaller heads" post.
FYI, back in the day of performance Corvette engines, like a 350/350, 165cc heads were the factory norm, and a performance upgrade meant 185cc runners. Anything bigger and you moved the entire powerband up the rpm scale, ruined the low end performance, and had lots of disappointing results. Bigger is not always better, and matching your components is everything. .02
St. Jude Donor '08-'09-'10
A little unsolicited advice, I'd pass on the Fast 92 and get the LS6 intake ported instead. You should be able to get it done for around $350 and with your cam and other mods it will be more than enough. Don't get me wrong, the Fast is a great piece just more than you need. Of course if you're planning more serious mods in the future then that could change things. Best of luck
If staying with 346cid....Use AFR 205's over AFR 225's. I've seen the results of people who have tried both on their 346 and the 225's only gained around 5hp up top but fuel mileage and drivability was worse. And if you ever go bigger than 346, you can always have Tony Mamo work some finger magic on them...
Former Vendor
Milled AFR 205's (62 cc's), an .040 gasket for better quench, and let me properly port/modify a FAST 92 intake for you along with an LS2 TB.
You already have the right cam (assuming your looking for a somewhat mild, powerful daily driver type set-up).....and with the heads and induction swap I think you can see an additional 30-40 HP with alot of area under the curve gains and much sharper throttle response at every RPM. Your buttmeter will think you gained more and some of that is the part throttle torque gains dyno's never measure.
The whole "ported FAST is too big for a mild combo's" is another Internet wives tale.....the heads determine whether a ported FAST is a wise move and with a really high flowing efficient set of heads it certainly is because a stock manifold (ported or otherwise) will chop off half the gains you paid for with the cylinder heads in terms of peak airflow....it simply cant keep up warranting the higher flowing intake.
Copy my former 346 package as much as you can afford to (arguably still the highest power I have seen from a 224 cammed combo) and you will be very happy.
Feel free to PM me if you have any questions or concerns. Or pick up the phone and drop me a line at AFR
(661)257-8124 Ext. 109
Cheers,
Tony
PS....And like others said, if your worried about the future when you may or may not go biigger, you can always send me the heads back to go thru by hand and still have plenty of cylinder head for a street/strip stroker motor. Check the results of Arkay99 and others with my ported/blueprinted 205 heads. They are even very effective on stock displacement builds if your looking for all the money from your combo (and your willing to invest more $$$ to get it).
Cheers,
Tony
hey, you stole my blanky! I've been looking all over for that.
nice project. do you have a thread with everything you are doing?
Cheers,
Tony
Cheers,
Tony
Where can we find the parts and specs write-up on your 346 package?
Will
Here?
As for the blanky, my kids old sheets sure come in handy for keeping out dirt and stuff, but I do take some crap for them
Former Vendor
Its a good read....more technical than most
Steve Dulcich was the editor and covered the story himself
-Tony
current mods:
Underdrive pulley
Underdrive pulley
if we dropped the LSA on that cam to say a 112+4 or 110+4 would that move the torque and HP curve to lower rpm range? Or how would that effect 'the curve?"
tom
Okay I have to ask. Mr. Mamo, your in Cali, I'm in Cali, the OP is in Cali, so does that set up pass smog?
No, but barely. The next lower AFR cam should though, I think it is on a 220/224 and is part 6018 (from memory).
Former Vendor
I have found the Gen III engines are not as effected (negatively) by a wider LSA than Gen II and especially Gen I carbuerated applications which really rely on the overlap more than EFI engines. Also, the better the head the wider the LSA typically (look at Pro Stock LSA's) so that's another reason why wide LSA's dont kill power much on these LS applications and offer advantages that I kind of prefer (better driving manners and idle quality and big power upstairs that really hangs on giving a very fat, flat, power curve in a combination thats really optimized.
-Tony
