Gas Cap Problems
Gas Cap Problems
I have an issue with my gas cap. I have an '04 Z06 and I'm on my second soon to be third cap. I replaced the faulty on with a new one from the dealer, but now I'm having the same problems.
The problem is I can take it off fine, but when I twist it to lock it down it just won't always lock in. The cap goes into immediate ratcheting mode as if it was tight!! Its really getting on my nerves!
Any and all assistance will be greatly appreciated !!! Thanks.
Ditto... cap problem just surfaced on my 04. Having to jiggle the cylindrical locking portion & the cap so it will release/reset/relatch. I expect a new cap is inevitable, but a wondered about a fix, too. JJ
Yep 3 here also for my 04. Another faulty Made in Mexico part! I finally gave up on the GM part and went to NAPA. $12 instead of 19 but it does not have the teather strap.
WOW, I haven't heard of this problem before ! Wonder if it is just with the 2004 Model ? I know the 2004 gas filter was changed to the new C6 type (filter in gas tank), maybe they changed the cap?
My 1998 has the original cap.
It must be an 2004 problem. I posted a question in the C6 Forum, asking if anyone had problems with their plastic gas cap. A few 2005's have already replied ! Some other years also replied.
Apparently 2005 C6's had a recall on the gas cap !
Premium Supporting Vendor
That is the code you would get from a gas cap not sealing
__________________
800-456-0211 / PM /E-mail Facebook AIM or Yahoo: JSSDPC
SDPC since 1929 thanks to you guys! WHIPPLE Superchargers, Procharger, Magnuson,
Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, Yella Terra, HPTuners, 7.400" pushrod set (other lengths available)
Received 1,674 Likes
I have a 04 and don't have that problem.
With two small flat bladed screw drivers I was able to take the tether off my factory cap and install it on the aftermarket cap. Used the flat ends sort of the way you would use tire irons to remove a tire from a rim. Took a little time but I now have a tether on the aftermarket cap.
Consider this. www.rockauto.com
8VETTE7:
Consider this. AC Delco part # GT276 $11.17 ea
Listed for '97 to '05 Corvettes.
http://info.rockauto.com/getimage/ge...imageurl=http%
Works great on mine.
