Balancing driveshaft
Hi - Had a rattle noise and vibration.
Dropped torque tube and found driveshaft weight was broken off causing the rattle noise and contributed to the vibration.
Also the rubber couplers were destroyed:
http://www.ponycars.net/c5coupler.htm
Do I find a shop to re-balance the driveshaft? (anyone in NY know a shop that does it?)
Or do I find a used driveshaft?
Thank you and happy 4th!
Wow ... that coupler is tore up pretty good. With some calling around I'm sure you can find a good shop that does driveshaft balancing.
How are those weights attached? What do you think caused the one weight to break off?
