•• All Injectors on sale! (FAST, Siemens, DeatschWerks) ••
Former Vendor
•• All Injectors on sale! (FAST, Siemens, DeatschWerks) •• HINSON Motorsports
All of our Fuel Injectors are on sale!
Most injectors will max out at 80% duty cycle and this is the accepted industry standard. After you install heads, cam, intake, your sucking in alot more air and your motor needs more fuel! Your injectors will be unpredictable when maxed out and you do not want to be running out of fuel at 6000+ rpm. If you have any questions about which injector size or accessories you may need, feel free to ask them in this thread. You can reach us at 205-267-6387 or seth@hinsonsupercars.com
High Impedance
FAST 33lb Injectors LS2
Part# 30332-8
DeatschWerks 35lb Injectors LS1
Part# 18U-01-0035-8
FAST 36lb Injectors LS1
Part# 303608
DeatschWerks 39lb Injectors LS1
Part# 18U-01-0039-8
FAST 39lb Injectors LS3/LS7
Part# 30397-8
Bosch 42lb Injectors LS1
Part# 0280155968
DeatschWerks 42lb Injectors LS1
Part# 18U-01-0042-8
DeatschWerks 42lb Injectors LS2
Part# 13U-00-0042-8
DeatschWerks 42lb Injectors LS3/LS7
Part# 16U-00-0042-8
FAST 46lb Injectors LS2
Part# 30462-8
DeatschWerks 50lb Injectors LS1
Part# 18U-01-0050-8
DeatschWerks 50lb Injectors LS2
Part# 17U-00-0050-8
DeatschWerks 50lb Injectors LS3/LS7
Part# 16U-00-0050-8
FAST 50lb Injectors LS3/LS7
Part# 30507-8
FAST 55lb Injectors LS1
Part# 305508
FAST 57lb Injectors LS2
Part# 30572-8
DeatschWerks 60lb Injectors LS1
Part# 18U-01-0060-8
DeatschWerks 60lb Injectors LS2
Part# 17U-00-0060-8
FAST 60lb Injectors LS1
Part# 306008
Siemens 60lb Injectors LS1 - EV1
Part# 107961
Siemens 60lb Injectors LS1 - EV6
Part# 108191
DeatschWerks 65lb Injectors LS3/LS7
Part# 16U-00-0065-8
FAST 65lb Injectors LS3/LS7
Part# 30657-8
DeatschWerks 72lb Injectors LS2
Part# 17U-00-0072-8
DeatschWerks 78lb Injectors LS1
Part# 18U-01-0078-8
Siemens 80lb Injectors LS1 - EV1
Part# 110324
Siemens 80lb Injectors LS1 - EV6
Part# 109991
FAST 85lb Injectors LS3/LS7
Part# 30857-8
DeatschWerks 88lb Injectors LS1
Part# 18U-01-0088-8
DeatschWerks 90lb LS3/LS7 Injectors
Part# 16U-00-0090-8
DeatschWerks 95lb Injectors LS2
Part# 17U-00-0095-8
Low Impedance
Lucas 120lb Injectors LS1
Bosch 160lb Injectors LS1
Fuel components you may need for your build
Caspers Electronics Injector Adapter EV1 to EV6
Part# 109076
LS2/LS3/LS7 Car using an LS1 Injector
Caspers Electronics Injector Adapter EV6 to EV1
Part# 109077
LS1 Car using an LS2/LS3/LS7 Injector
FAST Injector Harness Adapters - EV1 to EV6 (8 Pack)
FAST Injector Harness Adapters - EV6 to EV1 (8 Pack)
FAST Fuel Injector Spacer Kit
Makes an LS3/LS7 Injector have the same height as an LS2 Injector
Katech Fuel Rail Spacer LS2
LS1 Injector in an LS2 Manifold and Fuel Rail
High Impedance
Part# 30332-8
Part# 18U-01-0035-8
Part# 303608
Part# 18U-01-0039-8
Part# 30397-8
Part# 0280155968
Part# 18U-01-0042-8
Part# 13U-00-0042-8
Part# 16U-00-0042-8
Part# 30462-8
Part# 18U-01-0050-8
Part# 17U-00-0050-8
Part# 16U-00-0050-8
Part# 30507-8
Part# 305508
Part# 30572-8
Part# 18U-01-0060-8
Part# 17U-00-0060-8
Part# 306008
Part# 107961
Part# 108191
Part# 16U-00-0065-8
Part# 30657-8
Part# 17U-00-0072-8
Part# 18U-01-0078-8
Part# 110324
Part# 109991
Part# 30857-8
Part# 18U-01-0088-8
Part# 16U-00-0090-8
Part# 17U-00-0095-8
Low Impedance
Part# 109076
Part# 109077
I shoulda bought from U! I paid $400 for 60# injectors, and i haven t received them yet.(from a friend that s using them till his new combo is finished) I guess i shoulda checked around first.(understatement of my Corvette experience)
Former Vendor
Former Vendor
Seth
Former Vendor
I just installed a ls6 intake and ported throttle body on my 98 ls1, and was thinking about uprgading the injectors. Would new ones help me out any and if so, which ones should I get?
Former Vendor
Seth
Stupid question I know, but how bad will my car run from switching from the 60# injectors to the 83# injectors without changing anything in the tune.
Im going to get the car tuned for the 83s obviously, just curious as to what would happen with the switch w/o any changes.
Thanks!
p.s. whats the part # for these 83#ers?
Thanks!
Former Vendor
Thanks!
Thanks!
Seth
Question.........I have a darton sleeved LS1 with Total Engine Airflow ported L92 heads with 388 cubes, I'll be using the G6x3 Cam & the new FAST Intake. This is going into a 01 Z06. I already have a take-off LS3 Intake with injectors, but don't really think I want to use injector adaptors. What is the best way of setting this up for the long run & ease of installation? Thanks!
Former Vendor
Seth
I really don't know anything about injectors but i have a question. Do the injectors spray at the same rate all the time or does it just depend on how much/little throttle is used? Basically i'm asking if you have a 42lb injector car and 60lb injector car will you get worse fuel economy out of the 60 lb injector car if you drove both the cars exactly the same?
Former Vendor
They are not flow matched. This isn't necessary on new injectors.
Seth
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Planning on these mods to my LS1: AFR 205 heads (62cc), Fast 90 intake and TB, Comp Cam 224/230 .581/.588 114, LT headers. What injectors would you recommend. Also, are the SVO 30's really 36lb injectors? Thanks.
