List of c5 repair post that everyone should have!
cobrachuck (11-16-2018)
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hey,,,there handy for me too!!! I made it for handy reference. Thats why I posted it.. I had to keep searching for them to help other people and one night it hit me,,, "Hey,,why not just post this for everyone."
Im very happy for all the people who made the post and those who added to the post
Glad to be able to help..
Bill
Bill
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I keep forgetting to thank JACOBSJP for his additions!!
There really great post also!! I will add them to the body of the main post so that there all on one area. (if thats alright?)
Bill
Bill
added a link in the DIY thread
#33
CI 6,7,8,9,11 Vet
St. Jude Donor '08
#37
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Sway Bar replacement is fairly straight forward. Unbolt, remove and reinstall, torque the bolts in place.
Fronts: Disconnect the end links, remove the bolts that secure the bushings caps, remove the bar, reinstall the bar and torque the cap bolts in place. 40 ft/lbs Reinstall the endlinks. Strongly recommend using the ZO6 FRONT and REAR metal end links!!! The end link nuts are torqued to: 55 ft lbs
The rear sway bar cap bolts are installed and removed the same as the front except; The upper & lower cap bolts have TWO DIFFERENT bolt torques:
Torque specs:
The UPPER sway bar cap bolt are= 49 ft/lbs
The LOWER cap bolts are lower A arm suspension bolts and are torqued to: 70 ft/lbs. NOTE: If you over torque the UPPER cap bolts, you will strip them out. They do NOT secure suspension arm components!!
The LOWER sway bar cap bolts are part of the active suspension and secure the lower control arms to the cradle... They are secured with MORE torque than the upper bolts!
SHOCKS!
Shocks are easy! Unbolt and remove, reinstall! When you reinstall the shocks, I pre-compress the gas charged shocks outside the vehicle and use some nylon string to keep the new shock compressed until I have it in place.
Once the shock is in place, I cut the string and allow the pressurized gas in the shock to expand the shock and it expands into it's mounting position.
FRONT shock bolt Specs=
Upper bolts = 19 Ft/lbs
Lower bolts = 21 Ft/lbs
REAR shock bolt Specs =
Upper = 22 ft/lbs
Lower = 162 ft/lbs YEP,,,checked in TWO different service manuals! There robust bolts!
This is a EASY repair!
BC
Torque specs:
SHOCKS!
Upper = 22 ft/lbs
BC
#38
Torque specs:
SHOCKS!
Upper = 22 ft/lbs
BC
Torque specs:
SHOCKS!
Upper = 22 ft/lbs
BC
