List of c5 repair post that everyone should have!
#43
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
#44
Quote:
Originally Posted by C5C5RUN
Could someone give me a good tread for changing out the passenger window relay w/ pictures if possible....Thanks all
Try this:
http://forums.corvetteforum.com/show....php?t=
Bill , when i click this I am denied. I'm a member in good standing. it let me open anything else but the window thread.
Try this:
#45
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Its locking me out too. PM the OP and see if he can revive the post.
BC
BC
#46
I would like to know which relay is which. I have what i believe are the correct relay #'s, but not sure which relay is which. since I have it apart, I want to be sure to put the right relay in the right slot. Thanks Mr. Curlee for looking.
Relay #'s I have are NEC-EP2-3N15 & NEC-EP2-3N15T Both sold by Mouser Electronics
#48
3 cheers
Bill Curlee,,You Rock..
I just recently bought my 2nd Vette from a Corvette Forum member and I want to thank you in advance for all the articles you have posted.. I know I will eventually use them. There are a lot of other members that deserve some credit too..
Thanks Everyone
Bob
Thanks Everyone
Bob
#49
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thanks. That list really comes in handy. I just up-dated it wit all the new stuff that I have added to it.
BC
BC
#51
Everytime I answer someones post, I have to dig thru the archives or search my recient post to find the "POST" that I need to send the person to so that they can fix their problem. So,,,,I spent some time and I wrote down all the SERIOUSLY HELPFUL toutorial post that I could think of and put them all in ONE place.
So, here you go. :
________________________________________ ________________________________________ ________________
IMPORTANT C5 FORUM POSTS
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
- C5 Multifunction Switch repair - http://forums.corvetteforum.com/c5-t...f-replace.html
- C5 Pewter 99, The Ultimate DIY Thread .... with PICS - http://forums.corvetteforum.com/c5-t...post1571737259
- Tire pressure sensor rebuild - http://forums.corvetteforum.com/c5-t...post1570376652
- C5 Gage Cluster disassembly - http://forums.corvetteforum.com/c5-t...post1570380674
- C5 Gage Cluster Post - http://forums.corvetteforum.com/c5-t...post1570380878
- C5 Tire Pressure Monitor Sys Up-Grade 97-2000 to 2001 RFA System: http://forums.corvetteforum.com/c5-t...e-sensors.html , http://forums.corvetteforum.com/c5-t...aded-tpms.html
- C5 AC System Service and Repairs: http://forums.corvetteforum.com/c5-g...post1570703001 ,, Rocco’s post http://forums.corvetteforum.com/c5-t...post1571637102 , Compressor Replacement: http://forums.corvetteforum.com/c5-t...-write-up.html
- C5 Key FOB Repair Post: http://forums.corvetteforum.com/c5-t...post1570747451
The Ultimate DIY Thread .... with PICS http://forums.corvetteforum.com/c5-t...with-pics.html
- C5 No Start Thread: http://forums.corvetteforum.com/c5-t...post1571099773
- Everything I Know About a C5: http://forums.corvetteforum.com/c5-g...ngths-etc.html
- C5 Horn Membrane Fix: http://forums.corvetteforum.com/c5-t...brane-fix.html
- C5/C6 Shifter Install Thread: http://forums.corvetteforum.com/c5-g...tallation.html , http://temp.corvetteforum.net/c5/pat...rInstall.shtml
- C5 Alternator Disassembly Thread: http://forums.corvetteforum.com/c5-t...cs-inside.html
- Targa Top Refinish: http://forums.corvetteforum.com/c5-t...sh-how-to.html
- TSTAR Interior Led Light Up-Grade http://forums.corvetteforum.com/c5-g...od-thread.html
- C5, EBTCM troubleshooting http://forums.corvetteforum.com/c5-t...c-c1243-h.html
- C5, NUMB Transmission repair: http://forums.corvetteforum.com/c5-t...uild-saga.html
- C5, MIKER Fuel Sender Repair: http://forums.corvetteforum.com/c5-t...post1571514483
- C5, TRUSSME EBTCM DTC 1214 Diagnosis: http://forums.corvetteforum.com/c5-t...post1571568455
- C5 TICK Master Cylinder FACTS: http://forums.corvetteforum.com/c5-t...inder-kit.html
- C5, JBAUCH357, CV Shaft POP Repair: http://forums.corvetteforum.com/c5-t...-bearings.html
- C5, FL Dave, How to fix your hazard flasher/turn signal problem: http://forums.corvetteforum.com/c5-t...post1571702905
- C5, DPG, BIG 3 Wiring Improvement: http://forums.corvetteforum.com/audi...ig-3-pics.html
- C5, KC JEFF, HUD FIX: http://forums.corvetteforum.com/c5-t...post1571913016
- GM Service Manuals on CD: http://forums.corvetteforum.com/c5-t...al-on-dvd.html
- C5 SJBROTHERS, EBTCM DTC 1243 DC Current: http://forums.corvetteforum.com/c5-t...post1572045355
- C5 A.I.R. Check Valve post DTC P1416: http://forums.corvetteforum.com/c5-t...post1572083373 http://forums.corvetteforum.com/newr...1&p=1573420204
- OBDII Driving Cycle: http://www.obdii.com/drivecycle.html
- C5 WKMCD Torque Tube Bushing Replacement: http://forums.corvetteforum.com/c5-t...oday-pics.html
- C5, Bville Bud, Wiper Motor Repair: http://forums.corvetteforum.com/c5-t...post1572156474
- C5, dquagliaroli , Deprogramming F-55: http://forums.corvetteforum.com/c5-t...uspension.html
- C5 Intake Manifold Comparisons: http://www.tpis.com/index.php?module=2_17_06
- C5 Corvette Action Center C5 Owner Manuals: http://www.corvetteactioncenter.com/...ual-links.html
- C5 Bakersfield, How to fix a door lock or window problem : http://forums.corvetteforum.com/c5-g...w-problem.html
- C5 Toque Tire size calculator : http://forums.corvetteforum.com/c5-g...ah-issues.html
- C5 CHEVY 406, IPC Gage cluster exploration: http://forums.corvetteforum.com/c5-t...enter-dic.html
- C5 Rocking Seat Fix: http://www.lieblweb.com/c5seatfix.html
- Car Battery Knowledge Link: http://www.batteryfaq.org/
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5 ragtopws6, T-56 Build (whats in my tranny?) : http://forums.corvetteforum.com/nort...-smoother.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Intake Manifold Removal Oil Pressure service: http://forums.corvetteforum.com/c5-t...y-vectorz.html
- C5 Torque Specs: http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
- C5 INFO THREAD: http://forums.corvetteforum.com/c5-t...must-read.html
- C5 ZO6, Roof Trim Leak Repair: http://forums.corvetteforum.com/c5-z...post1575392999
- C5 Thermostat MOD & TESTING. VETNUTS: http://forums.corvetteforum.com/c5-t...test-data.html
-If you find a post that I missed or forgot about,,just add it in and I will add it to the main list.
Hope this helps someone!
Bill Curlee
up-dated 18 Mar 11
So, here you go. :
Bill Curlee
up-dated 18 Mar 11
#54
Cruising
great;
fat lot of good this does me, with Ample Annie (C5's have a tail big enough to marry) sitting in the drive one window partially closed and i cannot answer the one thread you have referring to the problem...
#55
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW! All you need to do is describe the issue better and ask for assistance. One archive post cant contain the answer to every problem..
Do "ANY" of the door functions work for that door?
Try opening the door, pressing the window UP button and while your pressing and holding it,, grab the rubber accordion tube between the door with your fingers and shake the hell out of it. If that corrects the issue or not, let us know.
AND
While pressing the switch close the door very hard.
If that doesn't work, you will have to remove the door panel for more troubleshooting.
#56
Bill,
When I try to open the door locks module repair link, I get a notice that I don't have sufficient priveleges to do that. The other links work fine, any ideas why? Thanks,,Jack
#57
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The link is a dead link. Dont know why.
