List of c5 repair post that everyone should have!
Received 2,180 Likes
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Everytime I answer someones post, I have to dig thru the archives or search my recient post to find the "POST" that I need to send the person to so that they can fix their problem. So,,,,I spent some time and I wrote down all the SERIOUSLY HELPFUL toutorial post that I could think of and put them all in ONE place.
So, here you go. :
________________________________________ ________________________________________ ________________
IMPORTANT C5 FORUM POSTS
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
- C5 Multifunction Switch repair - http://forums.corvetteforum.com/c5-t...f-replace.html
- C5 Pewter 99, The Ultimate DIY Thread .... with PICS - http://forums.corvetteforum.com/c5-t...post1571737259
- Tire pressure sensor rebuild - http://forums.corvetteforum.com/c5-t...post1570376652
- C5 Gage Cluster disassembly - http://forums.corvetteforum.com/c5-t...post1570380674
- C5 Gage Cluster Post - http://forums.corvetteforum.com/c5-t...post1570380878
- C5 Tire Pressure Monitor Sys Up-Grade 97-2000 to 2001 RFA System: http://forums.corvetteforum.com/c5-t...e-sensors.html , http://forums.corvetteforum.com/c5-t...aded-tpms.html
- C5 AC System Service and Repairs: http://forums.corvetteforum.com/c5-g...post1570703001 ,, Rocco’s post http://forums.corvetteforum.com/c5-t...post1571637102 , Compressor Replacement: http://forums.corvetteforum.com/c5-t...-write-up.html
- C5 Key FOB Repair Post: http://forums.corvetteforum.com/c5-t...post1570747451
The Ultimate DIY Thread .... with PICS http://forums.corvetteforum.com/c5-t...with-pics.html
- C5 No Start Thread: http://forums.corvetteforum.com/c5-t...post1571099773
- Everything I Know About a C5: http://forums.corvetteforum.com/c5-g...ngths-etc.html
- C5 Horn Membrane Fix: http://forums.corvetteforum.com/c5-t...brane-fix.html
- C5/C6 Shifter Install Thread: http://forums.corvetteforum.com/c5-g...tallation.html , http://temp.corvetteforum.net/c5/pat...rInstall.shtml
- C5 Alternator Disassembly Thread: http://forums.corvetteforum.com/c5-t...cs-inside.html
- Targa Top Refinish: http://forums.corvetteforum.com/c5-t...sh-how-to.html
- TSTAR Interior Led Light Up-Grade http://forums.corvetteforum.com/c5-g...od-thread.html
- C5, EBTCM troubleshooting http://forums.corvetteforum.com/c5-t...c-c1243-h.html
- C5, NUMB Transmission repair: http://forums.corvetteforum.com/c5-t...uild-saga.html
- C5, MIKER Fuel Sender Repair: http://forums.corvetteforum.com/c5-t...post1571514483
- C5, TRUSSME EBTCM DTC 1214 Diagnosis: http://forums.corvetteforum.com/c5-t...post1571568455
- C5 TICK Master Cylinder FACTS: http://forums.corvetteforum.com/c5-t...inder-kit.html
- C5, JBAUCH357, CV Shaft POP Repair: http://forums.corvetteforum.com/c5-t...-bearings.html
- C5, FL Dave, How to fix your hazard flasher/turn signal problem: http://forums.corvetteforum.com/c5-t...post1571702905
- C5, DPG, BIG 3 Wiring Improvement: http://forums.corvetteforum.com/audi...ig-3-pics.html
- C5, KC JEFF, HUD FIX: http://forums.corvetteforum.com/c5-t...post1571913016
- GM Service Manuals on CD: http://forums.corvetteforum.com/c5-t...al-on-dvd.html
- C5 SJBROTHERS, EBTCM DTC 1243 DC Current: http://forums.corvetteforum.com/c5-t...post1572045355
- C5 A.I.R. Check Valve post DTC P1416: http://forums.corvetteforum.com/c5-t...post1572083373 http://forums.corvetteforum.com/newr...1&p=1573420204
- OBDII Driving Cycle: http://www.obdii.com/drivecycle.html
- C5 WKMCD Torque Tube Bushing Replacement: http://forums.corvetteforum.com/c5-t...oday-pics.html
- C5, Bville Bud, Wiper Motor Repair: http://forums.corvetteforum.com/c5-t...post1572156474
- C5, dquagliaroli , Deprogramming F-55: http://forums.corvetteforum.com/c5-t...uspension.html
- C5 Intake Manifold Comparisons: http://www.tpis.com/index.php?module=2_17_06
- C5 Corvette Action Center C5 Owner Manuals: http://www.corvetteactioncenter.com/...ual-links.html
- C5 Bakersfield, How to fix a door lock or window problem : http://forums.corvetteforum.com/c5-g...w-problem.html
- C5 Toque Tire size calculator : http://forums.corvetteforum.com/c5-g...ah-issues.html
- C5 CHEVY 406, IPC Gage cluster exploration: http://forums.corvetteforum.com/c5-t...enter-dic.html
- C5 Rocking Seat Fix: http://www.lieblweb.com/c5seatfix.html
- Car Battery Knowledge Link: http://www.batteryfaq.org/
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5 ragtopws6, T-56 Build (whats in my tranny?) : http://forums.corvetteforum.com/nort...-smoother.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Intake Manifold Removal Oil Pressure service: http://forums.corvetteforum.com/c5-t...y-vectorz.html
- C5 Torque Specs: http://www.eliteengineeringusa.com/C5_Torque_Values.pdf
- C5 INFO THREAD: http://forums.corvetteforum.com/c5-t...must-read.html
- C5 ZO6, Roof Trim Leak Repair: http://forums.corvetteforum.com/c5-z...post1575392999
- C5 Thermostat MOD & TESTING. VETNUTS: http://forums.corvetteforum.com/c5-t...test-data.html
-If you find a post that I missed or forgot about,,just add it in and I will add it to the main list.
Hope this helps someone!
Bill Curlee
up-dated 18 Mar 11
So, here you go. :
Bill Curlee
up-dated 18 Mar 11
The following 19 users liked this post by Bill Curlee:
aphaynes (08-04-2016),
bigthaw (01-08-2019),
C5FAB (03-25-2017),
C5inWV (06-25-2016),
C5or66396ss (06-30-2016),
and 14 others liked this post.
ignition switch
Hey Bill I did read your write up on the ignition switch rebuild a while back and damn if I didnt need to do mine. The write up was great and it helped A ton , so thanks for the write up and I am sure that there are many more CF members that will say the same.
Richard
Richard
CI 6,7,8,9,11 Vet
St. Jude Donor '08
BC
Here are some more that I keep handy ....
- How to fix a door lock or window problem -
- Ground Locations -
http://pages.infinit.net/vette747/Ground
- Obtaining Codes on the DIC -
http://www.c5forum.com/ayc/dtcdic.php
- Horn Membrane Fix -
- Output Shaft Seal -
http://www.cajundude.com/outputshaftseal.htm
http://forums.corvetteforum.com/c5-g...e-junkman.html
- Oil Pressure Sender Removal and Relocation -
http://forums.corvetteforum.com/1562145914-post272.html
- Rocking Seat Fix -
http://www.lieblweb.com/TechLinks/Co.../C5SeatFix.htm
- Targa Top Refinishing -
http://forums.corvetteforum.com/c5-g...nted-roof.html
Bill, I will speak for many a corvette owner. THANKS
So, here you go. :
Bill Curlee
So, here you go. :
Bill Curlee
Bill,
are all these added in my C5 Tech DIY sticky??
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My ONLY goal is to bring some sanity to this crazy passion!
BC
BC
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Updated and bumped!
ENGINE IS NOT DOING VERY WELL. I may have to pull it. Not looking forward to it and neither is my bank account!
pewter99
Probably not. I can look thru your sticky and give you a list of ones to up-date. I created a couple of them not too long ago. Im about to make another C5 ELECTRICAL TROUBLESHOOTING & REPAIR 101 post.
I want it to be an all in one post to help the electrical/electronic challenged Corvette owners into troubleshooting & fixing their C5's
Bill
pewter99
Bill
St. Jude Donor '12-'13-'14
Thanks bill
I need to print four of these posts now cause im having issues, and two Ive used already
I told my wife my 2000 is starting to bug me like my 69 was when I sold it. She said are you going to go without a corvette, and I said no..
Then i got the $40,000 look
