Key Fob Problems
Key Fob Problems
After reading several threads about the issue of the key fobs. I purchased the car with the fob not working. I took it to the dealership and they tested the battery. The original battery was dead so I replaced it. I went to re-sync by holding down the lock and unlock button and that didn't work. So i reprogrammed the fob and after holding down the buttons for several seconds the computer never said that the fob was never synced. I then tried the fob inside the car and it worked. I turn the key off and get out of the car and it works for about 30sec then the next time you come up to the car it doesn't work. Has anyone ever had this problem or know the answer to the problem. This is a 99 FRC and the TPMS system is working fine. I only have one fob so I can't try the other one. Any help is appreciated. Thanks
St. Jude Donor '08-'09-'10
Classic symptoms of the dead FOB. Either get a new one from Gene Culley or do this:
http://forums.corvetteforum.com/c5-t...em-solved.html
As for the taking it to the dealership they didn't charge me anything, we have taken every car we own to this place and the guys in the service department have always helped me out on factory parts.
Ok thanks for the info. I've never used a solder gun, but I'll give it a try. Also who is Gene Culley?
For expensive items if you do your own servicing, Gene is the way to go. Great service goes along with what you will discover will be the cheapest price.
Have you checked for codes. My bro's car hads the same problem and he had brand new key fobs. He also had a 99 FRC.
Check for codes manually in the DIC.
Also check fuse #27 in footwell panel.
If you don't believe me look it up in the manual.
I probably know more about the wiring of these cars (C5) than most since I have converted from a coupe to FRC and from an auto to six speed.
It also helps to have a tech2 and dvd manual with wiring schematics.
Thanks for the info. I am new to the C5 world so i'm not sure how to check codes in the DIC? I will go check the fuse in the car right now though. Any help is appreciated. I'm usually mechanical, but this car is way different than anything i've worked on. I appreciate you guys being such a big help.
1. Turn on the ignition but don't start the engine.
2. Press the "reset" button to turn off any warning messages
3. Press and hold "options" and
4. While holding "options", press "fuel" four times within a 10-second period.
To enter the Diagnostic Display function perform the following steps:
1. Turn ON the ignition switch, with the engine OFF.
2. Press the RESET button to acknowledge any warning messages present.
3. Press the OPTIONS button on the Driver Information Center (DIC) and hold.
4. While holding the OPTIONS button press the FUEL button 4 times within a 5 second period.
5. System will first enter automatic display mode followed by the manual display mode.
Automatic Display DTC Mode
The automatic display feature allows you to read each module DTC display function in an automatic display sequence. Each system module DTC will be displayed for 3 seconds followed by a 1 second pause before the next DTC is displayed in an automatic sequence. If no DTC information is available from the system currently displayed on the IPC, the IPC will display NO CODES for that system. If there is a communications problem between any system, the IPC will display NO COMM when the IPC is trying to communicate with that system. When all DTCs have been displayed for all systems, the IPC will display NO MORE CODES for 2 seconds before entering the manual mode. At any time during the automatic display function, the manual display feature can be activated by pressing any button on the DIC except the E/M button. The E/M button is used to completely exit the DIAGNOSTICS mode at any time.
Manual Display DTC Mode
The manual display feature allows you to manually select each module DTC display function. The manual mode will automatically be entered after the automatic DTC display sequence is complete, or can be entered at any time during the automatic mode by pressing any button on the DIC except the E/M (E/M button is used to exit the DIAGNOSTIC mode at any time). When the manual mode is selected, the IPC will display the MANUAL DIAGNOSTICS mode message for 2 seconds, or until any button on the DIC except the E/M is pressed. After the MANUAL DIAGNOSTICS mode message is displayed, the IPC will display the first system abbreviation and quantity of codes stored for that system, then the IPC will wait for further instructions. The buttons on the DIC provide the following functions when operating the on-board diagnostic feature in the manual mode:
Yeah the TPMS system is working just fine. I even air up and down on a couple of tires to check that part of the system. I am a tire wholesaler so I'm very aware with the TPMS systems. What will I be looking for in the DIC as far as a code and in which system would I be looking?
Yeah everything in the DIC says no code. I am with you I believe that its the fob. I have spoke with JW on here about him trying to solder mine back together. If you know of anyone that is want to get rid of a 97-99 fob. The dealership here said 85 for a new one.
If so, try a new fob and hope that fixes your problem. Good Luck.
