KN Filter mod for Vararam
So if you have the old version of the vararam then this filter mod might be right up your alley!
The original version of the vararam has an very subpar foam "filter", if you could even call it that. I contacted vararam in an effort to upgrade the filter and they told me they now sell a filter upgrade but it includes a whole new redesigned upper portion. This enables their new filter to fit properly. Its something like 130 bucks for the upgrade...
If you don't want to go through all that and just keep the existing setup, but change out the filter, then this might be an option for you! Worked great for me!
Step 1) Buy this filter from K&N
http://www.knfilters.com/search/prod...x?Prod=33-2522
Its designed for the 1974 to 1982 Triumph line.
Step 2) Cut the edges off either end of the rubber seal on the filter as shown in the photo. This aids the filter seat correctly against the inside of the vararam upper duct.
Step 3) Take your old OEM vararam filter and cut off the outer rim as in the photo. CLEAN this foam rim as needed. Then make sure to laugh at the sight of the old crappy filter in pieces!
Step 4) Place your K&N filter in the vararam upper duct.
Step 5) Wedge in the old filter's foam outer rim into the gap around the new filter and the vararam upper duct. This helps the filter to make a nice seal in the duct.
I performed the same steps with one extra. In step 4, I roughed up the housing lip which the filter surround sat on and used a silicon epoxy to seal and secure the filter to the housing. When it is time to clean the filter you spray the filter as usual from the larger intake side while it is still secured in the housing. Then when ready apply the stream of water (I use a hose nozzel on spray) from the small duct end and direct all around the filter. Pretty simple.....and effective.
Will squelch all the naysayers who say "stuff" gets by the Vararam filter and the foam filter is useless.
Thanks for the great pics
Ed M
Ed M
Ed M
Ed M
Vararam sells the green filter for something like $60 and it fits the old housing just fine.
I got their kit but the new housing seemed to be to thick (front to back) at the filter opening and was jambing between the front bumper bar and the air duct for the rad. It just didn't want to drop down into the front of the car like the old one and then held the air bridge up off the top of the rad. On top of that, their new housing still had a very crappy gasket that did not seal to the filter. There were probably 1/8" gaps on each of the long sides between the filter and the housing. Honestly, it was just a waste of money.
So, I RTV'd the filter into the old housing. I j used a couple of little spring loaded clamps that held the filter in place while it dried. I'll just wash it in the housing when the time comes. No dirt will get by that seal.
They had all these new gaskets to make sure the filter sealed to the bottom half of the housing. It seemed really dumb - that's not the side where a leak will let dirt into the engine.
Peter
Peter
