0441 and 0361 HVAC Codes
went to have freon put in my AC today on my 2000 vette.. got there and the compressor wasnt turning on. turn the ac on in the car the the yellow light would blink and do nothing cause my temps was reading 20ish degrees.. replaced the sensor in the front passsenger side of the car and still the same.. now when i drive the car around the temps go back up to normal outside temps and i turn the ac on and it blows warm air.. NOT COLD AIR ON THE PASSENGER SIDE AND WARM ON THE DRIVER SIDE, just warm around through out.. when the temps set at 60.. blows hotter air as i turn it up though.. ive done searches and most of them seem to be one side blowin colder then the other side...
was gonna try pullin the fuse 27 here in a few and i have also cleared the codes out.. anything else i can try or should i just pull the actuator and either replace it or move the gears?
also if i just changed the head unit out to a 2002+ unit do i still have to change out the actuators before it will work right?
AC problem
Good luck
AC problem
Post whether the comp is running, and what the settings are and what the display reads, and also if there are any codes set, and we can help more.
Good Luck
compressor is runnin.. set at 60 all the vents blow the same but not cold. i had cleared the codes and i checked again and its showing the 0361 code again. there is an h at end if that matters..
