Dropping oil pan without dropping cradle?
Thanks, guys. That's what I was afraid of.
So next question:
Is the LS2 or LS3 a direct bolt in to replace the C5 pan when I get it off? I'd like to ditch the wings for easier access in the future. If so, which oil pan is the best choice and will I need to change anything like the oil pickup?
So next question:
So next question:
So next question:
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I Believe In The Beer Fairy
LS2 and LS3 pans are the same replacement part. Either fits and works fine. You're going to gain no cradle clearance by swapping, but you'll gain some working room at the sides of the pan.
So next question:
So next question:
Cruise-In VII Veteran
So, if you took a nasty hit and cracked the lower, YES you can swap the bottom plate of the pan IN the car. Local member just did one!!!
Clearance on the outside/around the pan is what I was looking for.
So the LS2 and LS3 is the same PN pan, or you are saying that either PN will bolt up fine?
