short shifter install question...
Old 08-15-2009, 07:05 PM
mischiefse7en
mischiefse7en's Avatar
Default short shifter install question...
I got the C6 Zo6 shifter for my car, but I have a question first. Is there a DIY that shows how to replace the whole assembly, box and all?
all the ones ive seen are just replacing just the top part, not the whole thing...
Old 08-15-2009, 07:19 PM
Patches
Support Corvetteforum!
Patches's Avatar
Installing the entire assembly requires loosening the two Torx screws that attach it to the tunnel as well as the coupler. You can use the shifter replacement procedure in the service manual to install and adjust it. I can email that to an address if you PM that to me. Meanwhile, here's a C6 shifter install thread I posted and a shifter install tutorial I did.
http://forums.corvetteforum.com/c5-g...tml?highlight=
http://temp.corvetteforum.net/c5/pat...rInstall.shtml
nsogiba (08-18-2016)
Old 08-15-2009, 07:31 PM
mischiefse7en
Thanks a lot. I actually just looked at the Hurst install about 10 minutes ago, thats what made me post my question lol. And your C6 install is the best I've seen and it should def be added to the Tech DIY sticky. Ive seen it before but I couldn't find it!
PM'd
Old 08-15-2009, 07:33 PM
Patches
Patches's Avatar
Procedures sent.
Old 08-18-2016, 11:48 AM
craigmp50
2nd Gear
craigmp50's Avatar
Default please forward service manual install & adj procedure
PM'd
I bought the TPS shifter, but I would really like to get a look @ the factory install procedure first.
tnanks
Old 08-18-2016, 01:38 PM
BMan0660
BMan0660's Avatar
There are tons of how-tos floating around.
http://www.corvettedreams.com/shifter.htm
http://www.superchevy.com/how-to/130...er-in-your-c5/
NVM, you're changing the whole box.
To short shifter install question...
Quick Reply: short shifter install question...
