P0418 and P0410
Old 10-07-2009, 07:12 PM
tjq
Cruising
tjq's Avatar
Default P0418 and P0410
Yesterday I was poking around in the fuse box looking for a blown fuse after finding the correct fuse to changed (thanks to lucky at the corvette forum) I got everything working fine. the next time I drive the car I got a check engine light. I read the codes and had 1 code set, P0418, and 2 pending P0410 and P0418. Anybody have any experience with these codes? I can't help to think I loosened something, maybe a ground, while poking around in the fuse box. Any help would be appreciated. Thanks in advance.
Old 10-07-2009, 07:32 PM
hotwheels57
hotwheels57's Avatar
Here's a complete list of codes. The rest is up to you...
http://www.stengel.net/diccodes.htm
Old 10-07-2009, 07:51 PM
tjq
Cruising
tjq's Avatar
sorry about the broken link I'll do better next time. Fuse was good so I erased the codes but don't have a good feeling about their return. I'll find out tomorrow when I drive to work. Keeping my fingers crossed...
Old 10-07-2009, 07:57 PM
tjq
Cruising
tjq's Avatar
Yea I know the codes just not familiar with P0418 AIR Pump Relay Control Circuit. Think that's where my problem is, just not sure where to trouble shoot this problem.
Old 10-07-2009, 11:25 PM
ALLEGRO
ALLEGRO's Avatar
Is it a history code or an active one?
Old 10-07-2009, 11:41 PM
ALLEGRO
ALLEGRO's Avatar
Originally Posted by lucky131969
I believe it has to be active to throw a check engine light....no?
It will throw the code regardless if it is an active problem or not. An "H" will come after the code if it has been corrected and is no longer an issue. The light will remain on until you clear the code(s) out.
Old 10-08-2009, 06:53 AM
tjq
Cruising
tjq's Avatar
It's an active one. As a matter of fact I cleared it last night and it came back on this morning as soon as I got out of my drivway. ARGH!!
Anyone know the first thing about troubleshooting the AIR Pump Relay Control Circuit? If I had a schematic I know I could figure it out...
Old 10-08-2009, 12:13 PM
tjq
Cruising
tjq's Avatar
Fill out your sig.
done
Old 10-09-2009, 05:13 PM
tjq
Cruising
tjq's Avatar
Ok. Now that I have the year, PM me your email so I can send you the info.
All fixed thanks to everyone especially lucky131969. Unseated relay #33
Old 09-02-2012, 12:56 AM
vanryan333
2nd Gear
vanryan333's Avatar
can you please email me the same fix you gave tig thanks pricejim@rogers.com
Old 09-02-2012, 10:55 AM
vanryan333
2nd Gear
vanryan333's Avatar
Default p0410 and p0418
mil light is on code p0410 and p0418 the vacuum line that runs under the battery and into a black plastic box can you tell me what it is and can i bypass it and run vacuum straight to air by-pass valve for secondary air injection thanks
To P0418 and P0410
Quick Reply: P0418 and P0410
