DIY Fix for the dreaded Falling HUD Display
Old 09-11-2011, 09:14 AM
  #41
brrymnvette
brrymnvette's Avatar
Awesome thread! Subscribing b/c this is my winter project.
Old 09-11-2011, 11:09 AM
  #42
ricknyc23
ricknyc23's Avatar
Now that you are a pro, you need to come help me do mine!
Originally Posted by Familycorvette
Thank you for this post.
I followed it step by step and mine is completed. It took me a while because I am very limited in my mechanic experience, but I finished it and it works just like it is suppose to.
Thanks.
Old 09-11-2011, 12:13 PM
  #43
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Very nice fix !!!
Toque
Old 09-11-2011, 02:40 PM
  #44
Familycorvette
Familycorvette's Avatar
Anyone can do this.
Follow the steps and it will go just like he said.
Old 10-02-2011, 06:44 PM
  #45
gotz06?
gotz06?'s Avatar
did mine today now it works fine! thanks for the great help.
Old 11-06-2011, 12:27 AM
  #46
FourG63 97GST
FourG63 97GST's Avatar
Originally Posted by FourG63 97GST
I love you man, I miss my HUD.
two years later I finally did mine! even though its midnight, i'm going to put my dash back together now, and take it for a drive!
Old 12-22-2011, 10:14 AM
  #47
AMiran
AMiran's Avatar
Great thread, glad to have my hud working again!
Old 06-18-2012, 07:37 PM
  #48
SacCityCorvette
Supporting Vendor
SacCityCorvette's Avatar
Location: SacCityCorvette.com in Sacramento Ca Join us on Facebook!
St. Jude Donor '12,'13,'15,'16,'17
Great Post!
__________________
Don't forget to check out our products at www.saccitycorvette.com
If you like our products, tell others! If not, tell us!
Old 07-09-2012, 10:46 PM
  #49
3whit
3whit's Avatar
I just used this last night ,great instructions and it works .Not that hard and I had nothing to loose .It didn't work so I gave it a shot. I love this Forum ,there is a tremendous amount of information available at the click of a key . Thanks my Forum Brothers
Old 04-17-2013, 08:37 PM
  #50
metalheadbusa
metalheadbusa's Avatar
hey out there.... my 99 c5 is giving me some troubles. i was looking for a vacuum leak after replacing the oil sending unit . so i removed the panel from right front wheel to find the line. i moved those wires some but not enough to unhook anything. but not the check engine is on and the car runs like there is a miss.any info will be help for .trying to get the ac fix before the summer heat gets here .please email at metalheadstunna@yahoo.com thanks
Old 04-17-2013, 09:44 PM
  #51
Bill Curlee
Support Corvetteforum!
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Well for starters,, your in a HUD Repair post. Recommend that you start your own thread and go from there.
Second, Are you SURE that theres not any ACID damage on the wires in that area???? If you see RUSTY Frame and white deposits on the wires,, It very well could be acid damage.
Do you have any DTCs?
BC
Old 04-17-2013, 10:15 PM
  #52
metalheadbusa
sorry about i just sent out a post i will pay more attention
Old 05-26-2013, 10:46 PM
  #53
Edmond
Edmond's Avatar
Looks like I'll be doing this tomorrow or next weekend.
This is a pic of my HUD taken with the camera resting on top of the steering wheel with the wheel all the way in the up position:
I must've broken something when I took the dash off and put it back on in April of last year. Yep, my lazy butt is just getting to it now.
Old 05-27-2013, 10:44 AM
  #54
Edmond
Edmond's Avatar
Did some more work. The tabs are not broke on the mirror so that didn't fix the issue. I tore it down some more after fussing with it for a little bit. The motor seems to work but the mirror still wouldn't display the HUD high enough. After tearing the HUD down, I noticed that the end piece plastic where the tab goes in was worn and loose. Just put some epoxy on there, I'll install in a few minutes and see if that solves the issue.
I moved the tab attached to the HUD motor and it moves freely but when I did that with the mirror attached, it didn't want to move. Hope this solves my issue.
Old 06-07-2013, 02:04 AM
  #55
ericstanley
ericstanley's Avatar
Huge thank you for this! I finally broke down and did this after seeing this post. So glad I did.
Now to reinstall the dash pad and put everything back together...
Old 02-08-2014, 07:15 PM
  #56
WCartee
1st Gear
WCartee's Avatar
Default hud
Originally Posted by phils C5 vette
My seat is all the way down to, but the up of the display seens to be projecting into the cover. Id like it to come up maybe 2 inches
Yours has probably been repaired at some point and the mirror isnt set back at the correct angle. took mine apart six times before I was able to get the correct angle. I'm 6-2 also now i have plenty of adjustment up and down.
Old 03-13-2014, 05:17 PM
  #57
jodyjo
jodyjo's Avatar
Just finished up my fix after following this article. Great information and fairly easy to do! Now someone come put my dash back in for me!
To DIY Fix for the dreaded Falling HUD Display
Old 05-16-2014, 10:46 PM
  #58
b_mouzakis
b_mouzakis's Avatar
Thank you, pictures are awesome and the explanation is also very detailed. I'm looking for instructions on how to remove my dash in a 2005 to make these exact repairs.
Bill
Old 05-26-2014, 03:53 PM
  #59
Lee DeRaud
Lee DeRaud's Avatar
The HUD bezel and the defroster vent are incredibly fragile, especially if the car has spent a good chunk of its life parked in the Florida sun like mine did. It's probably a good idea to go ahead and order replacements ahead of time.
Old 05-26-2014, 05:17 PM
  #60
Lee DeRaud
Lee DeRaud's Avatar
Another thing to watch for...
As you take off the cover, note that there is a cable going from the base to the cover for the (I think) light sensor. When you put it back together, make sure the cable is routed around the optical path, otherwise it will show up as a shadow on the display at certain angles. And you probably won't notice it until everything is buttoned up and you're driving in daylight.
Don't ask me how I know that.
Quick Reply: DIY Fix for the dreaded Falling HUD Display
