EBCM question?
EBCM question?
I purchased a used BPMV with the EBCM attached. My old BPMV is bad and the used pump has a EBCM on it. Here's my question will the EBCM with ABS-5/TCS/MSVA/AH work with the car. The one that came with the car has ABS-5/TCS/AH. I haven't installed the pump yet just wanting to see if this EBCM will work. I didn't get any codes from the original EBCM, so I assume I could put it on the used BPMV.
here'a a little help..
here's a list of EBCM part #s by year that you should check against the one that is on the BPMV you just purchased...if it covers the same year as your Corvette...then it should be fine...
EBCM Part #s:
Part Number: 10343433 All 2003-2004
Part Number: 12216561 All 2001-2002
Part Number: 9367071 All 1999-2000 w/o Control Active Brakes
EBCM Part #s:
