Removing A.I.R. pump, what codes to tune out with hptuners?
Banned Scam/Spammer
Received 1,319 Likes
I'm changing the exhaust as I'm fully polishing the engine in my '01z.
The ugly air system is not in the game plan. I bought the block off plates for the mainifolds and will remove all air hardware.
I have hptuners, what codes will I need to turn off, and is there anything else I should consider?
Thanks.
Thanks.
Thanks.
Thanks.
Banned Scam/Spammer
^that sounds good. So basically turn up the temp to something impossible so it never comes on.
One thing though. I'm removing the pump since it would just be dead weight and clutter. With it unplugged I'm worried about a code.
Former Vendor
AIR
P0410 AIR System
P0412 AIR Solenoid relay control circuit
P0418 AIR Pump Relay Control Circuit
P1415 AIR System Bank 1
P1416 AIR System Bank 2
Seth
P0410 AIR System
Seth
Cruise-In VII Veteran
you can also remove the T under the Batt. for the vac, some years do not run vac. to the AIR pump
Hinson's codes are also referring to the relays down in that area
AIR tubes are a pita for plug and/or LT swaps
Josh, keep us updated on the polishing progress, the previous motor was insane
Banned Scam/Spammer
^ Thanks for the tip.
The engine's about 60% done. Buying a house and my 4 month old son are taking away some of my "car time"
I need to start taking pictures!
Banned Scam/Spammer
Loosened the bolt (which isn't bad if you have the proper tool- I had a 13mm stubby wrench) and it slips right off.
Everything is out except for dropping the panel below the bumper and getting the air pump itself and the rubber hose running between it and the engine bay.
