do I need an additive for my rear differential?
Old 11-20-2009, 02:13 PM
wildbadbill
wildbadbill's Avatar
Default do I need an additive for my rear differential?
I've put a synthetic gear oil in it.....thanks.
Old 11-20-2009, 02:34 PM
lucky131969
lucky131969's Avatar
Depends on the brand. What are you using, and what do they recommend?
Old 11-20-2009, 02:41 PM
Cybermind
Cybermind's Avatar
When I changed my diff oil, I refilled it with the OEM GM gear lubricant (which is synthetic). I did also add the recommended additive.
When in doubt, you should add it or you may have to live with rear end noise. I don't think it can hurt.
Old 11-20-2009, 03:53 PM
mjorgensen
mjorgensen's Avatar
Any diff with clutch plates needs a diff additive unless you want the max lock up and can live with a very short lifespan and the noise.
Old 11-20-2009, 04:05 PM
dankhts
dankhts's Avatar
add the whale sperm and be done with it
Old 11-20-2009, 04:19 PM
87SAM
87SAM's Avatar
As Lucky alluded to, it depends on the brand/type the OP used as some has the additive already in it.
Old 11-20-2009, 04:33 PM
Swt_86
Swt_86's Avatar
Normally the synthetic lube will have the letters "LS" on the label if they have the limited slip additive already. In theory, you should not have to add the "friction modifier" from GM if you use the "LS" lube. Personally, I didn't take a chance and got the regular synthetic then added the GM stuff.
Old 11-20-2009, 05:56 PM
wildbadbill
thanks guys
Old 11-20-2009, 09:48 PM
Last C5
Last C5's Avatar
[QUOTE=Swt_86;1572190157]Normally the synthetic lube will have the letters "LS" on the label if they have the limited slip additive already. In theory, you should not have to add the "friction modifier" from GM if you use the "LS" lube. Personally, I didn't take a chance and got the regular synthetic then added the GM stuff.[/QUO
Careful with Redline, the 75/90 NS means that it does not have the additive in it and the standard Redline 75/90 does have the additive.
Old 01-21-2010, 07:19 PM
Jet-Jock
Support Corvetteforum!
Jet-Jock's Avatar
Is it possible for someone to define the "noise?"
Old 01-21-2010, 09:04 PM
Mike Mercury
Mike Mercury's Avatar
I think some believe that just because the oil is "synthetic"... that this alone means it doesn't require any additives. Of course; this is not the case though.
The original GM rear gear lubricant (12378261) did not have the modifier... so you needed to add it.
The newest GM lubricant (89021677) does have the friction modifier already mixed in.
Old 01-22-2010, 12:17 AM
Carcass
Carcass's Avatar
Mobil 1 LS75W-90 doesn't need additives.
To do I need an additive for my rear differential?
Quick Reply: do I need an additive for my rear differential?
