FAST LSXRT 102mm Intake Manifolds (4.8/5.3/6.0L Truck) in stock!
Former Vendor
We just got our shipment in on the all new FAST LSXRT 102mm Intake Manifolds for the 4.8/5.3/6.0L Trucks.
$939 shipped - FAST LSXRT 102mm Intake Manifold (4.8/5.3/6.0L Truck)
Designed specifically for GM 4.8/5.3/6.0L cathedral port truck engines and cathedral port LS1, -2, -6 race applications where hood clearance is not a concern, the FAST™ LSXRT™102mm Intake Manifold follows the path chartered by the original FAST™ LSX™ Gen III Intake by featuring a modular design that allows for easy porting and disassembly and a runner design that yields an incredible 25 peak horsepower gain over the stock intake, on a stock 6.0L engine with a Big Mouth 102mm Throttle Body™. And similar to the LSXR™ 102mm Intake Manifold for cars, the LSXRT™ features the ability to remove individual runners for modification.
The LSXRT™ is constructed from a proprietary precision injection molded polymer which offers many benefits, including lighter weight, greater strength and lower heat soak propensity. While it features a 102mm air inlet that was designed for the FAST™ Big Mouth 102mm Throttle Body™, it can also be used with stock 90mm or aftermarket 92mm throttle bodies (78mm three-bolt throttle bodies require an adapter). Other features include integrated nitrous bungs and precise bolt-on fit that permits the use of factory accessories and OEM fuel/emission connections without adjustments or clearance issues. Some GM truck models may require the FAST™ 92mm or 102mm throttle body.
Former Vendor
Seth
