C6 Z06 front spring fit a C5 ?
from what i have read c6 and c5 front ends are pretty similar...
would the spring fit a C5?
if so anyone know .... the spring rate of a C6 Z06 front spring?
I assume it would work...but as far as spring rate goes, it was designed to hold up a 7.0L motor as opposed to a 5.7L. Should be stiffer in theory. Interested to know if anyone has tried.
Just because the displacement is larger, does not mean the engine weighs more.......
What are those weights based on?
The LS1 is almost the same motor as an LS6.
Could that be the difference between a clutch/fw/pp combo and a flexplate? Still seems heavy unless one has the harness and ECU piled on top of it too.
Premium Supporting Vendor
Those weights aren't right at all. The LS6 weighs 50 pounds more than an LS1 and an iron block 5.3 weighs less than the LS6 and only 20 pounds more than an LS1? I'm not sure how they obtained those weights, but something isn't right.
Here is some numbers for you:
Since you mentioned Z06 springs, for rate comparison purposes:
C6 Base Springs(lbs) Fr 420/Rr 657, Sways(mm) Fr 25.5/Rr 17.5
C6 Z51 Springs(lbs) Fr 526/Rr 645, Sways(mm) Fr 31.0/Rr 25.6
C6 Z06 Springs(lbs) Fr 531/Rr 782, Sways(mm) Fr 31.0/Rr 27.9
Sourced from:
http://forums.corvetteforum.com/1569355821-post9.html
Thanks,Matt
Sourced from:
Thanks,Matt
Sourced from:
Thanks,Matt
Sourced from:
Thanks,Matt
Ok, since you guys deal in crate motors every day, what are the correct weights?
So can you use the springs or not
Resident moron
They should all be pretty much the same weight.
The LS7 might be a little lighter with titanium rods but then you have to add in the dry sump oiling system which I'm sure adds a pretty considerable amount of weight (nevermind the oil itself).
Dope
