rear window defroster timer
Old 01-18-2010, 10:42 AM
fatbillybob
fatbillybob's Avatar
Default rear window defroster timer
Anyone know how to take the timing function out of the rear window defroster circuit?
Old 01-18-2010, 11:00 AM
byronhunter
byronhunter's Avatar
Yea! Hook a up a seperate Switch to ground Circuit #193, White Wire.
Old 01-18-2010, 11:08 AM
lucky131969
lucky131969's Avatar
It appears the easiest way would be to have a switched ground(manually) to relay 44, instead of the BCM supplied ground. You would have to remember to shut it off, as the defogger would be on at all times, provided the ignition was on........and you left the switch on.
******edit******** Wow, Byronhunter, that was fast!
Old 01-18-2010, 12:05 PM
byronhunter
Sometimes!!! But I still can't keep up with you.
To rear window defroster timer
Quick Reply: rear window defroster timer
