C5 CV Joint 101
Old 01-27-2010, 02:33 PM
Allthrottleandsomebottle
Support Corvetteforum!
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Default C5 CV Joint 101
CV Joint 101
For those that care & have never seen one apart, here ya go below. While reassembling my 97’ drive train once again, I finally made the DS CV joint assy come apart during reinstall. I used to design/install BMF steering axle assemblies for big off road vehicles with CV joints, so I figured I would disassemble a C5 and check it out.
For those that wonder why CV joints vs. u-joints, this page does a good job explaining it:
http://www.cvaxles.com/cvhelp.htm
Here is how it goes together:
More pics Here: http://forums.corvetteforum.com/phot...y.php/cat/1531
I ended up buying a cheap core form a CF member, turned it in and got a NAPA remanufactured for $62 out the door with a 3/36K warranty. Easy for me to swap later if there is a problem. I kept my original 97’ as the only thing wrong was the large wire ring was distorted from me removing the assy from the car a few times. It popped loose and allowed by ***** to fall out (hate when that happens!) So I just need grease & clamps and it’s good to go. Minor wear on the race & ***** as I expected, but still not much based on all the racing this one has seen. Just proves how good Constant Velocity joints are at smooth torque transfer. So if your CV joint doesn’t install back in the rear easy, you may have this very problem
Old 01-27-2010, 02:55 PM
vette.mix
vette.mix's Avatar
Thanks for the info
Old 01-27-2010, 03:00 PM
~Josh
Banned Scam/Spammer
~Josh's Avatar
Received 1,319 Likes on 788 Posts
Subscribed for future reference..
Old 01-28-2010, 01:16 AM
00Corvette
00Corvette's Avatar
What are some symptoms of a bad CV axle on a C5?
I know what to look for on a front wheel drive, the click click click click when you accelerate exiting a corner or basically just a cracked boot...but what can I look for besides the boot on our cars?
I only ask because I have about 126K on my 00 now and I have had a slight vibration at certain high speeds and also on corner exit acceleration. Initially I was thinking torque tube bearings but this thread got me wondering...
Thanks,
Donnie
Old 01-30-2010, 12:06 PM
mariofromnewyork
Late Model Domestics
mariofromnewyork's Avatar
Subscribed!
Old 01-30-2010, 01:44 PM
sami85L98
sami85L98's Avatar
Oh did not know that Rzeppa fixed point CV is in our cars, i thought we should have plunge type, but who cares ours is RWD anyway.
how did u took that snap ring thing took off?
Old 02-03-2010, 02:22 PM
Cruise-In V Veteran
NCM Ambassador
Thanks,Donnie
Could be the TT rubber bushings, clutch? Have you looked at the CV joint boots to make sure they have no cuts & the lube is gone?
Steve
Old 02-03-2010, 02:42 PM
Cruise-In V Veteran
NCM Ambassador
Well placed small flat blade screw driver pops it right out with gentle pressure
Old 02-03-2010, 02:48 PM
TEXHAWK0
TEXHAWK0's Avatar
Facinating!
Last edited by Allthrottleandsomebottle; 02-03-2010 at 03:03 PM. Reason: It is for those who don't know............
Old 02-03-2010, 08:20 PM
BOTTOMS UP
BOTTOMS UP's Avatar
sounds like good times
Old 02-03-2010, 08:56 PM
00Corvette
00Corvette's Avatar
Steve,
Thanks for reply. My cars an auto so can't be the clutch. I'm sure it's the TT bushings/bearings so I'll just replace em'. I have looked at the CV boots and they aren't cracked so...I guess it just leaves the PIA TT bushings.
Oh well.
Donnie
Old 02-04-2010, 11:42 AM
Eric D
Eric D's Avatar
St. Jude Donor '09-'10-'11
Steve,
How is the stiffness of the boots on your NAPA replacement shaft compared to the OEM? There were a few comments in the C6 forum area about some of the aftermarket replacements having too soft of boots installed. They would balloon at speed allowing them to hit other components that would cut the boot.
Old 02-05-2010, 06:52 AM
Cruise-In V Veteran
NCM Ambassador
Originally Posted by Eric D
Steve,
Hey Eric,
I had read about the soft boot issue before. Compared to my 14 Year old OEM ones they are twice as soft. Can't says I ever checked OEM/replacmenet boots for a Shore durometer hardness number.........but I plan too I have a few OEM boots to use if that becomes an issue It would only take me 15 minutes to get the CV assy out if it becomes a problem. I am sure NAPA and I will review the issue if the boot does self destruct
Old 02-05-2010, 08:27 AM
SteveDoten
SteveDoten's Avatar
good info; BMF, is that like a 'BMF' hammer?
some of those rock crawlers have some sick articulation
Old 02-05-2010, 10:18 AM
Cruise-In V Veteran
NCM Ambassador
size comparison..........The brake rotors were 70 lbs ea!
Old 02-05-2010, 10:49 AM
Eric D
Eric D's Avatar
Do they use the same (6) number of ***** and what diameter were they?
Old 02-08-2010, 10:24 PM
BOTTOMS UP
BOTTOMS UP's Avatar
Hammer is BFH
To C5 CV Joint 101
Old 02-08-2010, 11:30 PM
Brandon619
Brandon619's Avatar
Good info I messed up a CV boot a year or so ago and I bought boot repair kit from GM. This was a great kit, when I took apart the CV joint I was very impressed on the quality of the CV. I had no luck though sealing up the boot so my point is to just buy a rebuilt one form napa becaue I bought a NEW one from GM and it was pricey.
Old 02-09-2010, 06:18 PM
M_T_0
M_T_0's Avatar
had a boot crack in the past but a whole axel assembly with both cv's boots and shaft was around $200 so i just replaced the whole thing with an OEM part
Old 02-10-2010, 03:31 PM
BOTTOMS UP
BOTTOMS UP's Avatar
56 bucks at rockauto for a complete unit LAST TIME i CHECKED
Quick Reply: C5 CV Joint 101
