Any AIR Check Valve Relocation Kits For Sale?
Was wondering if anyone has come up with and sells a kit to cleanly relocate the driver's side AIR check valve from behind the engine to the passenger side head location.
The driver's side AIR check valve is out in the open and easily accessible ... too bad GM didn't do the same thing for the passenger side check valve. It looks like a relocation kit could be made up pretty easily.
So what brand replacement AIR check valves is "solid" compared to the OEM part. All the aftermarket check valves I've seen also have a rubber flapper valve, and they too will eventually get baked and harden when buried behind the engine instead of out in the open like on the drive's side head.
I'm not sure you if you know what check valve I'm talking about.
The reality is, no one is going to create a relocation kit, for something you don't need......
Well, guess you were luckier than me ... mine started acting up at 18K miles and died at 22K miles. I need to replace it now, so was just wondering IF anyone might have a relocation kit out here for sale ... apparently not.
If you are the ambitious sort, you can do your own relocation. At least one person has done it on the forum.....think there was a thread on it last year.
Does the 2000 LS1 engine have this ....
...AIR check valve on the Passenger side? I looked down between the pass side cyl head and firewall and don't recall seeing it.
I currently have my intake removed for the oil sensor relocate project and would like to replace the valve with a new one while the intake is removed.
Thanks in advance.
Thanks in advance.
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Thanks in advance.
Thanks in advance.
The slotted tab you see fastens to the rear of the pass. side head.
Tuned those codes out.
I'm not running cats, so the AIR system is useless to me.
Ah, OK. Thanks for the pic Y2K.
The check valve is the near black part in the upper right hand corner of your photo. I replaced one of those on my '88 F250 while on the vehicle which was a bear of a job.
Should I go to the dealership for that part or would an Autozone/Advance/NAPA be a better route?
St. Jude Donor '03
oops, yeah, I just looked at it and judging by the distance from tab to the bend around the pass head, you'd be correct.
I took it off like 4 years ago, I must have thought of that wiring harness clamp that fastens to the rear of the pass. head. Another fun fastener to get to.
Wonder if you took off intake manifold to replace air check valve and cut off tab bolting it to head if you could just unbolt line from passenger side and disconnect from drivers side hose and push it through from behind intake enough to replace valve again if you had to. ( or pull it out from passenger side)
Thanks in advance.
Thanks in advance.
Yes, DEFINITELY replace the AIR check valve if you already have your intake manifold off!! It's a $12 part from Autozone (or other parts stores) and cheap insurance to replace it. The ACDelco part from the dealer is about $35 I think.
ZeeO,
1) I spent 20 minutes at my local Chevy dealership parts counter and we could not come up with a GM part number. The exploded view he has on his computer does not show the tubes or check valves.
Do you know what the GM part number is? If I had it I could call around town and get one.
2) Also, other than the GM dealership, which requires 5 days to get, where can I buy the fuel injector O-ring replacement kit????
thanks,
thanks,
