auto swap parts list...
Old 02-16-2010, 02:03 AM
ragu1585
ragu1585's Avatar
Default auto swap parts list...
i currently have a 6speed in the car and started my process of buying/collectin parts for an auto swap.. i would appreciate it for any1 who has done this to give me a detailed list of parts i need to complete the swap.... thanks and much appreciated
(ps i searched and couldnt find one - search is not my friend haha)
Old 02-16-2010, 02:32 AM
ragu1585
ragu1585's Avatar
im lookin for a list of parts that i will need to complete the swap...
i know ill need:
auto tranny
auto torque tube
the 2 lines from cooler to tranny
tranny cooler
converter
auto harness (does it matter what yr, mines a 2000)
what else am i missing here...
also will my 6speed pedal assembly work or do i have to buy one from an auto
Old 02-16-2010, 09:17 AM
MattB
Support Corvetteforum!
MattB's Avatar
I went the other way, but can give you some info. You WILL need to get the GM shop manual for your year Vette. It will have all the wiring diagrams you will need, and you will need them as you will need to run some additional wires to the PCM. Gene at www.gmpartshouse.com has great prices on them, and the new parts you will need. And, yes you will need a new transmission wiring harness, it is different than the manual one. I would have sold you my old one, but it was damaged and I threw it out.
Shifter, and the linkage to the ignition switch (not sure if you need a new switch)
You will also need the bracket that attaches the drive shaft of the torque tube to the flex plate on the engine. And the flex plate.
Your pedals will be fine.
I'll try to think of what else you need, but hopefully those that have done this swap will chime in. Also you may want to talk to RPM transmissions or another vendor that has done the swap before.
Old 02-16-2010, 09:45 AM
TurboBerserker
TurboBerserker's Avatar
i know ill need:
auto tranny
auto torque tube
tranny cooler
converter
The pedal box will work if you pull it and swap the pedal from an auto.
You also need the auto bellhousing (they are different), flex plate with collar, a shifter, shifter cable, park lock out cable, and the diff plate.
I have a tranny with 1500 miles, the torque tube and the cooler lines that are attached to it, a fuddle 3200 converter, and diff plate. Get 'em out of my garage I also think I still have the auto pedal box and think I have the flex plate with collar, but need to check. Let me know if you are interested.
I can also help you with the wiring changes when you get to that point (I recently went from auto to manual and kept my "whitebook" on that process).
Old 02-16-2010, 09:50 AM
TurboBerserker
You don't need a new ignition switch, they are all the same.
I believe the flex plate should come with the collar if purchasing new from GM. If you buy a used flex, you really need to make sure it's still true and has no cracks and need to source that collar.
Old 02-17-2010, 01:49 AM
ragu1585
ragu1585's Avatar
thanks for the help and if theres anything else someone can think of that may have been left out!.. the cars got a 408 and will be driven at the track.. also i have my own site and a sponsor for me is doing the swap i just want to gather parts to take to him... also ill let him worry about the wiring as i know hes done the swap before (i will be buyin the harness and taking it to him)
turbo ill be sending u a pm in a few
Old 02-20-2010, 12:00 AM
Gene Culley
Premium Supporting Vendor
Gene Culley's Avatar
Thanks for the referral. I would certainly be happy to help out.
__________________
Phone: 484-334-8833
Owner of CULTRAG Performance
Shop Our Factory GM Parts Website
Old 02-20-2010, 06:11 AM
oakvillec5
oakvillec5's Avatar
Gene's the man
Old 02-20-2010, 10:17 AM
SteveDoten
SteveDoten's Avatar
Cruise-In VII Veteran
I have the a4 bellhousing, flexplate and cooler lines ready to go
Old 02-22-2010, 12:58 AM
ragu1585
ragu1585's Avatar
ok so far...
tranny,
differential,
shifter and linkage,
torque tube and bell housing,
trans lines from the radiator,
trans cooler,
console,
converter,
fly wheel,
flex plate w/ collar,
park lock out cable
anything else....
Old 02-22-2010, 01:04 AM
BLOWNBLUEZ06
BLOWNBLUEZ06's Avatar
You will have to get a segment swap. You will have to find a tuner or someone to pull your tune before the swap and send it off to get it done while you are in the exchange process and then flash in the new tune when you are ready to use it. Contact RoadRebel. He is the man for the segment swap job. Also, you will need a tranny harness and there are different ones. It depends on the connections you have up front at the PCM. You are close to the cutoff year between harnesses, so call RPM transmission and ask. RPM also sells a some little jumper harness for ~250.00 that you are going to need, so cover that with them while you're talking turkey.
Old 02-22-2010, 01:40 AM
ragu1585
ragu1585's Avatar
my shop has done the swap a time or 2 so they will be handling the wiring and tune at the time of the swap. as far as the harness im going to be getting with speartech for their harness adapter
Old 05-15-2010, 07:49 PM
99vetteran
99vetteran's Avatar
Why did you change the diff, they should be the same.
Old 08-19-2013, 08:30 AM
adi4
adi4's Avatar
To auto swap parts list...
Quick Reply: auto swap parts list...
