Will OEM C6 Wheels Fit a C5 ?
Old 10-31-2015, 08:31 PM
  #61
kflohrit
kflohrit's Avatar
Originally Posted by MickVette
That bothered me too at the time. I went forward with it. I currently have about 65,000 miles on the adapters. Been across the country once, Pacific Coast Highway (US1), RT 66, and daily driving with no issues so far. I am only running Firestone Wide Oval tires in the stock size on the stock C6 rims so I'm sure the adapters aren't being stressed as much as they would be with a stickier tire. I would like to go with a wider rim and "stickier" tires all the way around but I'm not sure how much wider we can go under these cars without a mini tub or flaring the fenders.
I thought the ZR-1 rims were wider than the regular C6 rims?
They are replicas with the C6 offset. I installed them today.
Old 11-03-2015, 08:42 PM
  #62
MickVette
MickVette's Avatar
St. Jude Donor '13
Looks good!!!
Old 11-03-2015, 09:51 PM
  #63
Doug1
Doug1's Avatar
Great looking wheels and car MickVette!
Old 11-03-2015, 09:58 PM
  #64
kflohrit
kflohrit's Avatar
Looks good!!!
Thanks! Now I can fit Z06 brakes behind them!
Old 11-04-2015, 11:08 AM
  #65
ddent01
ddent01's Avatar
Default C7 Wheels - offset
Originally Posted by rjwz28
Yes
The offsets are the same as C6, and there's a ton of threads; use spacers or adapters, as they'll sit further in if you don't
I have a set of 2014 C7 wheels/tires (18 and 19) that required a 1" adapter on rear wheels to keep them from hitting on the inside frame.
Ordered adapter set from Motorsport Tech and will be here today.
NOTE: I also have to replace the TPMS sensors as the C6/C7 uses a different frequency than C5. I have plans to use Discount Tire to replace sensors and re-balance wheels.
Will upload pic's once I get finished this week.
Good to see some feedback on long term use of adapters. Motorsports Tech provides a lifetime warranty so they feel confident with their product.
Old 11-04-2015, 06:27 PM
  #66
huesmann
huesmann's Avatar
You should use the same TPMS sensors for your year of car (or conversion), not the TPMS sensors for the year of the wheels, correct?
Old 11-04-2015, 07:50 PM
  #67
ddent01
ddent01's Avatar
Default C5 alternative wheels
Yes, you have to use the TPMS sensors correct for your car year, not the wheels installed.
gmpartsdirect offers the OEM C5 TPMS for $47 / each and my local Discount Tire matched the price so just letting them install theirs.
BTW, here's a pic of 2014 C7's on my C5.
Just installed today with 1" rear wheel adapters from motorsports tech. Perfect offset
Sorry for the poor pic's but it was dark and rainy by the time I finished.
Old 02-14-2016, 04:19 PM
  #68
My2000C5
5th Gear
My2000C5's Avatar
Default Spacers
Where can I find the 1" spacer for my C5? I'm putting C6 OEM wheels and Tires on my C5. TIA
Old 02-14-2016, 06:08 PM
  #69
ddent01
ddent01's Avatar
Default Wheel adapters
I got mine from Motorsports Technology in Reno NV.
Lifetime warranty and it's all they do. Have about 3k on then since installed.
Rides smooth as silk ... tested up to 120+ for a brief spin.
I put factory C7 wheels on so can't attest to aftermarket wheels.
Sorry, I don't visit this site anymore due to the issues it causes my browsers.
BTW, I think I only put on 3/4" spacers on the rears and they fit perfect.
Fronts didn't need anything.
Old 02-14-2016, 09:43 PM
  #70
ArtGle
Support Corvetteforum!
ArtGle's Avatar
Default C6 Wheels '
Motorsport Technology
280 South Rock Blvd, Suite 100
Reno NV 89502
Phone: (775) 351-1000
Email: motorsportjr@gmail.com
Fax: (775) 351-1600
Web: http://www.motorsport-tech.com
Here's where I got mine.
7/8" thick.
Hub and Wheel Centric
$155.oo
And worth every penny.
Old 02-14-2016, 09:50 PM
  #71
ArtGle
ArtGle's Avatar
Default Rear only need spacers
See the attached image.
Inside the rear wheels, you should see a number like this.
19 X 10 with a "J" number
Mine are J79
Which required a 7/8" adapter to clear the tires from the frame inside.
Good luck.
Old 02-14-2016, 09:56 PM
  #72
ArtGle
ArtGle's Avatar
Default C6 Wheels
Here are shots of my car with the wheels on with the 7/8" adapters.
Nice and flush with the body.
Old 03-28-2016, 11:28 AM
  #73
Internetguru
Internetguru's Avatar
Not C6 wheels... But this thread is one of the ones that inspired me to put OEM C7 Z51 rims on my C5.
Fronts fit perfectly. For rear fit I used a 5/8" Doug Rippie Motorsports spacer & 2.5" ARP chrome molly studs.
https://www.corvetteforum.com/forums/c5-general/3800500-new-shoes-for-my-millenium-yellow-2004-c5.html
Last edited by Internetguru; 03-28-2016 at 12:07 PM. Reason: wrong length ARP studs I used 2.5" not 3.25"
Old 02-15-2017, 08:34 AM
  #74
ZAZZ
ZAZZ's Avatar
this is a good read.. ive been looking into c6/c7 wheels for my c5.. but honestly, unless you find a REALLY good deal on OE wheels, or repros.. it almost seems like you can get some TSW's or good aftermarket wheels for about the same price as these, once you buy the rims, the spacers, new TPMS sensors etc.. your well over a grand.. or am I missing something?
I have chrome wagon wheels on my car now, can I re-use these TPMS sensors on c6/c7 wheels? or if I go with TSW's, will they work on them? for something that seems as simple as a wheel and tire swap, it can get complicated !!
Old 02-15-2017, 11:09 AM
  #75
ZAZZ
ZAZZ's Avatar
thanks for the additional info.. and since from what I can tell, the valve stem is integrated into the TPMS, im assuming that the shop that mounts and balances the tires, has to have these when they mount and balance my tires on the new rims??
thanks. this forum is very helpful to a new vette owner
Old 09-10-2017, 05:57 PM
  #76
Hellcamino
2nd Gear
Hellcamino's Avatar
Default Yes oem c6 wheels fit
Originally Posted by Advancetec
I have a stock 1998 C5 and found oem wheels for sale off a 2006 C6.
They are 18" Front and 19" Rears.
Will they Fit?
If they will bolt on, will there be any rubbing since my wheels now are 17" fronts and 18" rears?
HI . They work well in my car no rubbing.
Old 09-11-2017, 04:45 PM
  #77
vetterdstr
vetterdstr's Avatar
CA Events Coordinator
Originally Posted by 8VETTE7
Responding to a thread that started in early 2010 and the thread starter hasn't logged into the Forum since June of 2012.
My guess is he don't care any more!!!
Ya just can't take some people anywhere huh!
Quick Reply: Will OEM C6 Wheels Fit a C5 ?
