odd request. Headlight plug harness plastic clip part #
the part that retains the big plug under the hood up front to the chassis of the car. I looked in the c5 parts list pdf and couldn't find it. Any help would be appreciated.
Dave
Dave
Cruise-In IV Veteran
Daytona Jam 1 Veteran
Is the part you are looking for attached to the radiator support? Is it part of the wiring to the front DRLs?
Let me know and I will take a look for you.
The large plug that attaches to the headlight motor assembly on each side of the car is secured w/ this plug and held to the frame w/ a clip that pushes into a hold in the car.
It would be the grey plug in this picture:
Dave
Dave
Dave,
as you probably have seen, there is no part # on that clip/plug on either side. As I follow it on my passenger side it merely goes into the headlight motor and the control module but with no part #.
I am thinking you should send the picture to forum vendor of used parts Corvette Recycling and also to Gene Culley at gmpartshouse who is also a vendor.
I am guessing you may be able to get that specific part used but would have to buy a much larger set of parts sold as a whole (with one part#) if you buy new.
Sorry that looking at the parts catalog I could not determine which part# belongs to what you need.
Best of luck with your search and I am sure C/R or Gene can get more info for you.
I figured there wasn't a p/n as it is so small. Id assume lots of GM cars use these clips I just need to find one. The clip is only 1/2" long by 1/4" wide if that I think w/ a little nipple on it to press into a hole in the car. Thanks for you help though>
Daev
Daev
I know exactly the part you are talking about, and like the others, I can't find it listed as a seperate item either. It's a retainer that slides into a slot on the underside of the gray plug you show and there is a "one way" pin so-to-speak that then plugs into a hole in the fender liner. I'm thinking bone yard.
HTH
HTH
