Oil drain plug leak....?
Old 10-29-2010, 11:58 PM
robsc501
robsc501's Avatar
Hi There,
Next time you drain the oil out.Install the stock d/plug & tighten. Then take a propane torch (House hold type) heat the bolt for appox. 10 minutes. If its not too distorted this will pull the inside of the oil pan tight against the drain bolt.Let it cool naturally.
robsc501
Quick Reply: Oil drain plug leak....?
