Would a wiring problem in passenger door cause "reduced engine power", RDCM issue?
Every now and then my passenger door's power is inoperable (window, lights, lock) and if I open it and shake the rubber boot in the door jam it will work for a while until it does it again. Today I started driving my car and noticed ALL of my DTC warnings going off.. Service traction control, reduced engine power, check gauges, etc. So I pulled over and pulled all my codes.. there were none current, except there was RDCM: NO COMM.
I noticed my doors power wasnt working again, so I shook the rubber boot and got it to work... and the NO COMM went away as well as all of the DTC codes. Would that cause the issue? I saw the thread here http://forums.corvetteforum.com/c5-t...ndow-inop.html which basically says take off the boot and make sure the wires are in there good which I plan on doing. It's just weird to me that my car would freak out like that from such a small issue...
