How Do I Re-Set Oil Life Remaining?
Old 04-07-2010, 05:10 PM
c6800hp
c6800hp's Avatar
Default How Do I Re-Set Oil Life Remaining?
How do i re-set my oil life remaining after an oil change? I went to guages, pushed until I got to oil life remaining then pushed reset but nothing happened. I want to make it 100% as I had the oil changed recently but the oil life remaining was not re-set to 100%. How do I do that ? Please help
Scott
Old 04-07-2010, 05:13 PM
Y2Kvert4me
Y2Kvert4me's Avatar
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Easiest way:
Turn ignition on, but don't start the car.
Push the gas pedal to floor 3 times quickly.
Your oil life will now read 100%.
Old 04-07-2010, 05:18 PM
c6800hp
c6800hp's Avatar
Is that true? Not to question your sincerity, but I never heard of that.
Old 04-07-2010, 05:20 PM
Y2Kvert4me
Y2Kvert4me's Avatar
St. Jude Donor '03
Yes, I believe it works on any GM car with the oil life monitor. Works the same on my 2004 Silverado too.
And, it's easy enough for you to go try. No, you won't flood your car, no fuel will be injected with the engine not running.
Old 04-07-2010, 05:44 PM
dougbfresh
dougbfresh's Avatar
Anybody ever read their Owners Manual anymore?
Old 04-07-2010, 05:46 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,911 Likes on 5,325 Posts
Doesn't work on C6 Vettes or some other newer GM cars.
Bill
Old 04-07-2010, 05:59 PM
pdvale
pdvale's Avatar
Scott
Show the oil monitor on the DIC and press and hold reset.
Old 04-07-2010, 06:15 PM
lucky131969
lucky131969's Avatar
.....but I never heard of that.
He must be lying then.....
Old 04-07-2010, 06:57 PM
Evil-Twin
Evil-Twin's Avatar
Received 3,812 Likes on 1,925 Posts
St. Jude Donor '03-'04
the new forum members make coming to this forum a real treat...its better than watching ****..... wait a minute..:o that cant be true..
Old 04-07-2010, 07:18 PM
Gray Ghost GS
"AlohaC5" Senior Member
Support Corvetteforum!
Gray Ghost GS's Avatar
or use the "search" feature?
Old 04-08-2010, 04:01 AM
Rohan
Rohan's Avatar
Page 6-15 in the 1999 Corvette Owners Manual
"How to Reset the Engine Oil Life Monitor"
1. With the ignition on, press the TRIP button so the OIL LIFE percentage is displayed.
2. Press RESET and hold for two seconds. The word RESET will appear, then OIL LIFE 99%.
Pg. 6-16 What to Do with Used Oil... Oh, sorry.
Old 04-09-2010, 12:17 AM
0austin@RPM
Former Vendor
austin@RPM's Avatar
Easiest way on a c6 or c5
1)turn ignition to on, but to not start engine
2)press trip until the oil life shows
3)hold the reset button and depress the gas pedal 3 times
works every time!
Old 04-09-2010, 09:35 AM
sts57c5
sts57c5's Avatar
Easiest way:
yes this works i did this the last time my oil was changed.
To How Do I Re-Set Oil Life Remaining?
Quick Reply: How Do I Re-Set Oil Life Remaining?
