Service ABS, Service Traction Control, Service Active Handling
Old 04-24-2010, 08:31 PM
  #41
hank_rearden1
hank_rearden1's Avatar
Default Thanks for the write-up OUTSTANDING!!
Originally Posted by trussme
ITZ on the way, Hank...
Bill,
Thanks for the info.. outstanding write-up!
Unfortunately for me, my DTC code is different than the ones in your write-up. My DTC is:
C1277 Requested Torque Signal Circuit Malfunction.
Have you seen this one before?
My symptoms are:
It happens once every 3 or 4 starts. When the errors do come up, they typically go away once everything warms up. Sometimes I can make it go away by powering down and starting back-up (even when the engine is cold).
I confirmed that I do not have a p/s fluid leak. I cleaned up the ground connections in the engine compartment really good and made sure they are making good contact. I also added dialectic grease.
I had the car in for a dyno tune recently and the shop guys said they didn't encounter the errors [I had cleared out my codes before takign it in to the shop] but I had them disconnect and reconnect the sensors / connectors on the wheels. Interestingly, the problem did not come back until a couple days (6 or 7 starts) later.
What do you think?
Thanks.
Old 04-25-2010, 12:10 AM
  #42
jeffreyswkam
1st Gear
jeffreyswkam's Avatar
Default asb and active handling warning lites
Bill,
Please send me the infor, I've getting the same warning lights.
Jswkam@yahoo.com
Old 04-25-2010, 05:36 AM
  #43
trussme
trussme's Avatar
Originally Posted by jeffreyswkam
Bill,
Jswkam@yahoo.com
Jeffrey, SENT...Bill
Old 04-25-2010, 08:36 AM
  #44
Etz
Etz's Avatar
Sounds like this should be a sticky? Put me in line for the info when you do another mass sending. Thanks
ericetzler@gmail.com
Old 04-25-2010, 10:27 AM
  #45
Sea Ray Mark
5th Gear
Sea Ray Mark's Avatar
Bill, can you send it to me also? Thanks. marksimone1@yahoo.com
Old 04-25-2010, 10:44 AM
  #46
wwwFLA
wwwFLA's Avatar
William,
Please send to me also.
Thank you,
Old 04-25-2010, 02:42 PM
  #47
trussme
trussme's Avatar
just sent to above 3 requests
Old 04-25-2010, 05:37 PM
  #48
odysseus1
odysseus1's Avatar
St. Jude Donor '11
Bill , you are very kind to assist us and it appears that you have been very busy also! BUSY (engaged in something requiring time or attention). Would you add me to the list? Odysseus1946@aol.com Thanks and Good luck.
Old 04-25-2010, 05:57 PM
  #49
harrell3us
harrell3us's Avatar
I am another one, Mr. Bill, please. Also, is there any way to reset engine light without going to dealership?
harrell3us@msn.com
Old 04-25-2010, 07:13 PM
  #50
zbc51
zbc51's Avatar
Can you send on please
zbc51@comcast.net
thanks
Old 04-26-2010, 06:22 AM
  #51
trussme
trussme's Avatar
Default reset check or service engine light
harrell3us@msn.com
harrell3us,
here is the guide for checking codes & resetting warning light:
with the key in the on position, but the engine not running
push and release the reset button until all messages cleared
next push and HOLD button #4
next push and release button #1 four times while holding button #4
When first engaged the on-board diagnostics go into an "automatic" mode which shows all parameters: PCM-TCS-RTD-BCM-IPC-radio-HVAC-LDCM-RDCM-SCM-RFA. If there are no problems, you will see "no more codes" on the ICP display. The computer will show two kinds of codes, "current" and "history," designated "C" or "H". A current code indicates a malfunction is present in the system whose module is displaying data. A history code indicates a past problem. When the screen displays "manual diagnostics," select the desired module by pressing the "options" button to go forward or the "trip" button to go back. Press "gages" to go forward or "fuel" to go back. To exit the diagnostic mode at any time, press "E/M".
If you want to erase or "clear" codes, press .""reset
Old 04-26-2010, 06:24 AM
  #52
trussme
trussme's Avatar
last 3 tutorial requests, have been emailed...
Old 04-26-2010, 08:21 AM
  #53
03WhiteConv
03WhiteConv's Avatar
Crud, looks like I'm in this not so exclusive club...Can I get a copy too?
swearingencj@hotmail.com
Old 04-26-2010, 12:35 PM
  #54
Steve Jones
Steve Jones's Avatar
Bill,
I would like to have a copy as well.
s.jones.4001@sbcglobal.net
Thanks in advance,
Steve
Old 04-26-2010, 02:49 PM
  #55
brightonvette
brightonvette's Avatar
Bill,
Would like to request a copy also.
rmcbrighton@yahoo.com
Thank you in advance, you are spending a lot of time on this thread and we all thank you for your help.
Randy Clifton
Old 04-26-2010, 02:53 PM
  #56
1965markaccount
1965markaccount's Avatar
Sir you are a gentleman and a scholar. I would also appreciate a copy of the tutorial. I read a few post up that it should be a "sticky". Certianly seems any number of people could and would use the information. Thank you in advance.
magellenthedog@gmail.com
Old 04-26-2010, 05:35 PM
  #57
trussme
trussme's Avatar
all preceding requests have been emailed
To Service ABS, Service Traction Control, Service Active Handling
Old 04-26-2010, 05:43 PM
  #58
devious1
devious1's Avatar
c.mcclaran@yahoo.com Thanks in advance!
Old 04-26-2010, 10:38 PM
  #59
cobra3
cobra3's Avatar
Bill , I got the email and printed it all out . Thanks for sending it to myself and all the others that needed it. Bill you are the man , Thanks
Old 04-26-2010, 10:44 PM
  #60
brightonvette
Bill,
Received mine also. 16 pages of good info, the pictures really helped. Thank you,
RMC
Quick Reply: Service ABS, Service Traction Control, Service Active Handling
