Finally..Convertible top leaks repaired..
My 2000 Vert leaked like I didn't have the top up at all. Water just poured in over the windows and especially down from where the top meets the pillar. I spent a year trying to stop it. I used dowels to plump up the weatherstrip. I used RTV in the places I knew it was leaking. I adjusted the tension a hundred times. Tilted the windows as far in as they would go. Nothing worked. The thing is, the weatherstrip looked good ! No tears, no rips, no distortion.. I finally bit the bullet, paid the Corvette tax and bought the six pieces of weather stripping for the top. I was amazed when I removed the old and compared it to the new at how much the 10 year old strip had SHRUNK... Installed the new, made a few adjustments and hit it hard with direct streams of water. Perfect.. no drips or leaks. I can now safely wash it and not worry about getting caught in the rain which always seems to happen at Michigan car shows...
I have the same problem with my 2000,if you don't mond me asking what was the damage? and who did you order through? one more question,what 6 pieces did you order?
It appears that I made the vertical installation more difficult than need be. By laying the top back down with the cover open you can access the plug button securing the weatherstrip to the top. Pull it out and save it for reinstallation on the new one.
Dukenukemx (07-10-2023)
6th Gear
Thank you for info!!! This is a big problem for me too!
This kit include stock gm parts (10236327+10236328+10236329+10236330+104 15919+10415920)???
or this is modify (advanced) gm parts for recovery this problem?
Thank you!
Thank you!
I had the same problem with air leaks on my 00 where the rear vertical weather strip met the glass in the upper corner. I could pass a doubled up paper towel between the glass and the seal in the upper 4" area.
I was about to take the door pannels off and adjust the glass inward when i noticed that the vertical weather strips are made with a soft aluminum frame, I thought what the hell, lets see if its malible. It is, I was able to push on the aluminum frame in the upper corners and move the weather seal out the 16th of an inch or so i needed to seal the air leak.
These are stock GM parts. I never found any aftermarket and am sure there will never be any due to low demand. The problem is that the old ones just wore out, shrunk and lost their shape. Even though I lubbed them often. They look good, but are really worn out.
As for the aluminum channels they go into, once my old stripping was out I could see where some had been bumped and distorted (probably from lowering and raising the top). They can be easily bent back into shape. It is not as obvious with the strips inserted, but they definately can be moved out to better fit against the window. There are 2 screws holding each channel to the top and there is a slight amount of adjustment in them also when replacing with new W/S. I would not go in there if not replacing though.
Left car out last night. Rained hard all night... Approached car with great apprehension even though I had tested it with a hose a couple times... Bone dry inside... wish I had done this a year ago... Finally I can drive with a dry butt....
