Question on Z06 Yellow Valve Springs
Anybody know what the maximum lift that a set of Z06 stock yellow springs could handle? I saw a statement in an LSx How To book that "LS6 springs - depending on your camshaft specs - could handle any street requirements" but what does that mean exactly.
Do Z06 guys that upgrade their cams have the same concerns/issues about the valve springs that an LS1 upgrade would have?
Brand GM Performance
Manufacturer's Part Number 12586484
Valve Spring, Beehive, 90 lbs. @ 1.8 in., 295 lbs @ 1.250 in., .570 in. Maximum Lift, LS6/LS2,
Product Line GM Performance LS6 Valve Springs
Number of Springs Per Valve Single
Outside Diameter of Outer Spring (in) 1.290 in.
Coil Bind Height (in) 1.085 in.
Damper Spring Included No
Spring Rate (lbs/in) 375 lbs./in.
Inside Diameter of Outer Spring (in) 0.885 in.
Valve Spring Style Beehive
Coated No
Coated No
